BT.com
Wishlist
StarTech.com 50 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M
Delivery
Standard Due date unavailable
The MXT101MMHQ50 High Resolution VGA Cable (50ft) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 50 ft Coax High Resolution VGA Monitor Cable - VGA cable - 15.2 m
VGA cable
Triple shielded twisted pair coaxial
Molded , ferrite bead
Length
15.2 m
Connector
HD-15 - male
Connector (Second End)
HD-15 - male
P/N: ST122LEU, VGA2TV2WAY2, ST122LE, ST128LGB, ST122LGB, ST128L, ST124L, ST122L, VID2VGATVGB, VGA2TV2WAYGB, VGA2DVIIGB, VGA2DVII, VGA2TV2WAY, VID2VGATV, ST222MX, SV421DD, SV221DVI, SV221DD
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
15.2 m
Connector
StarTech.com 2 Port DVI PS/2 KVM Switch, 2 Port Matrix High Resolution VGA Video Splitter, 2 Port VGA Dual Monitor KVM Switch with PS/2, 2 Port VGA Video Splitter - 250 MHz, 2 Way High Resolution HDTV VGA Video Converter with Scaler, 2 Way VGA HDTV Video Converter with Scaler, 4 Port VGA Dual Monitor KVM Switch with PS/2, 4 Port VGA Video Splitter - 250 MHz, Component / Composite / S-Video to VGA / HDTV Scaler / Converter, Composite and S-Video to VGA Video Converter, VGA to DVI-I Video Converter with Scaler , StarTech.com VGA Video Splitter / Distribution Amplifier 8 Port - 250 MHz
Scroll to top
