BT.com
Wishlist
StarTech.com 5 Port PCI High Speed USB 2.0 Adapter Card
Delivery
Standard Due date unavailable
Add 5 USB 2.0 ports to any desktop computer with a PCI slot. This PCI-based High Speed USB 2.0 Adapter Card adds five USB 2.0 'A' Female ports (1 internal, 4 external) to your PCI-capable PC.
Supported by popular operating systems including Windows 98SE/ME/2000/XP/Vista, the PCI USB 2.0 card is a versatile solution that lets you add USB 2.0 connections without having to upgrade the system motherboard.
A convenient and time-saving solution, the PCI USB card is WHQL certified to simplify driver installation in Windows XP operating environments, and supports USB device hot-swapping - allowing you to connect/disconnect USB peripherals without having to power down the computer.
StarTech.com 5 Port PCI High Speed USB 2.0 Adapter Card - USB adapter - 5 ports
USB adapter
Plug-in card
Interface (Bus) Type
PCI
Ports Qty
5 ports
USB 2.0
Data Transfer Rate
480 Mbps
Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows 2000 / XP
P/N: SAT3520U2RGB, SAT3510U2VGB, SAT3510U2V, UNI3510U2, SAT3520U2R, SAT3510U2, ICUSB1284D25, SAT3510U2B, FCREADHC, ICUSBAUDIO, IDECAS35NAGB, SATCAS35U2GB, IDECASE35NAS, SATCASE35U2
Plug-in card
PCI
Wired
USB 2.0
Data Transfer Rate
480 Mbps
4 x USB 2.0 - 4 pin USB Type A (external) , 1 x USB 2.0 - 4 pin USB Type A (internal)
Compatible Slots
1 x PCI
Plug and Play
Software Included
Drivers & Utilities
Limited warranty - lifetime
StarTech.com 14-in-1 USB 2.0 High Capacity Silver Multi Media Memory Card Reader, 3.5in USB to SATA External Hard Drive Enclosure w/ One Button Backup , StarTech.com InfoSafe 3.5 inch USB 2.0 Network Storage HD Enclosure, 3.5" USB 2.0 SATA Aluminum HD Enclosure, 3.5" USB 2.0 SATA Hard Drive Enclosure, 3.5" USB 2.0 to IDE/SATA Hard Drive Enclosure, 3.5" USB 2.0 to SATA Drive Enclosure, USB 2.0 Dual 3.5" SATA Drive Enclosure w/RAID
Accessories
£5.67
£5.32
£4.66
£4.58
£3.79
£4.45
Scroll to top
