BT.com
Wishlist
StarTech.com 5.25 Bay 2.5 and 3.5 SATA Dock
Delivery
Standard Due date unavailable
Easily connect and swap 2.5in and 3.5in SATA drives from a 5.25in front bay. This SATA hard drive dock/docking station can be mounted internally in a 5.25in computer drive bay, to provide simple access to 2.5in or 3.5in SATA hard drives.
Featuring a convenient trayless design, the internal hard drive dock doesn't require that hard drives be mounted in an enclosure, saving time and hassle. Once the docking station is connected to the host computer, it's as simple as inserting the desired SATA hard drive into the slot(s) as needed for full access to the hard drive(s) as though installed conventionally within the computer case.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
The HDD dock accommodates both 2.5in and 3.5in SATA hard drives and can support one of each at the same time. Plus, when the 3.5in slot is not in use, two 2.5in drives can be inserted simultaneously.
The 5.25in bay-mounted SATA Hard Drive Dock features front panel power control, allowing you to power the drives on/off as needed.
StarTech.com 5.25in Bay Mounted 2.5in and 3.5in SATA Hard Drive Dock - storage bay adapter - SATA 3Gb/s
Storage bay adapter
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Compatible Bays
1 5.25" x 1/2H
SATA 3Gb/s
Supported Devices
Hard drive
Max Storage Devices Qty
2
Power Source
eSATA bus
Microsoft Windows XP, Microsoft Windows Vista
10.8 cm x 14.5 cm x 0.4 cm
240 g
2 years warranty
Storage bay adapter
Storage Controller
SATA 3Gb/s
Supported Devices
Hard drive
2
Bays
2 x SATA 3Gb/s - 7 pin Serial ATA
2 storage - eSATA-300 - 7 pin external Serial ATA
Compatible Bays
1 x external 5.25" x 1/2H
Power Source
eSATA bus
2 years warranty
Service & Support Details
10.8 cm
14.5 cm
0.4 cm
240 g
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* 3,5 Drive hangs out of the Front
Reviewed by Anonymous on 21/07/2010
When considering this enclosure pay close attention to the physical size of the device.
It isn't actually large enough to fit a 3.5 drive inside. It is designed to have the drive protruding from the front of the bay.
Fine if you want very temporary access to a disk, but for longer term use it is not suitable.
Scroll to top
