BT.com
Wishlist
StarTech.com 4x4 VGA Matrix Video Switch Splitter with Audio
StarTech.com 4x4 VGA Matrix Video...
£223.68
Hurry, only 1 left in stock!
£223.68
Add to wishlist
Delivery
Standard 1-3 working days
Share up to four distinct VGA inputs and audio source signals between multiple monitors. The ST424MX 4x4 VGA Matrix Switcher/Splitter allows users to share up to four distinct VGA inputs (as well as corresponding audio source) between four independent displays or projectors.
Providing convenient push button control, the VGA Matrix Switcher/Splitter allows each of the four input VGA signals and the corresponding audio, to be switched individually meaning that you can have a different source showing on each display or one source showing on both offering maximum flexibility and control.
To ensure optimized VGA distribution and signal management even over longer distance signal transmissions, the ST424MX VGA Matrix Switcher/Splitter features a built-in signal booster that facilitates installation of displays at distances of up to 210ft away from the source device, while maintaining flawless signal integrity.
Designed to provide maximum control while saving space and eliminating clutter, the ST424MX can be used as a standalone solution or rack mounted using the (included) ear-mounts.
StarTech.com 4x4 VGA Matrix Video Switch Splitter with Audio - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
VGA / audio
26.9 cm x 10.4 cm x 4.2 cm
1.1 kg
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
VGA / audio
Max Resolution
1920 x 1440
Max Video Bandwidth
350 MHz
4 x VGA - HD-15 , 4 x audio - mini-jack , 4 x VGA - HD-15 , 4 x audio - mini-jack
External power adapter
Rack Mounting Kit
Included
FCC, RoHS
26.9 cm
10.4 cm
4.2 cm
1.1 kg
Accessories
£14.28
£6.90
£11.25
Scroll to top
