BT.com
Wishlist
StarTech.com 4in Rack Depth Adapter - 2U
StarTech.com 4in Rack Depth Adapter...
£22.26
2 in stock
£22.26
Add to wishlist
Delivery
Standard 3-5 working days
Add flexibility to your rack by expanding or reducing the equipment mounting depth by 4 inches. This depth adapter kit lets you extend or reduce the mounting depth of two rack units (2U) in your server rack by up to four inches. If you're using the adapter kit in a two post installation the extenders can support a total weight load of 20 lbs. (9 kg). If you're using the adapter kit in a four post installation, the extenders can support a total weight load of 130 lbs. (59 kg), you can even use two sets of extender brackets in a four post installation and achieve the same weight capacity performance.
This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
You can use this adapter kit to mount equipment in your server rack that's up to four inches longer or shorter than the rack's mounting depth.
With this adapter kit, you can customize your server rack to support different mounting depths, so you have the freedom to mount equipment of different depths in the same rack. It’s a cost-saving, hassle-free way to consolidate your equipment into a single rack, so you have one server rack to manage instead of two.
The depth adapter kit can also help manage your cables. You can mount equipment 4" in from the rails, to prevent cables from protruding from the rack. You can use the rail depth adapter to mount equipment that has high density cabling, such as patch panels, PDUs or network switches, to minimize the effects of cable strain and provide easier access to the cables.
StarTech.com Rail Depth Adapter Kit for Server Racks - 4 in. (10 cm) - 2U - rack rail adapter - 2U
Rack rail adapter
Height (Rack Units)
2U
2 years warranty
Rack rail adapter
Height (Rack Units)
2U
TAA Compliant
Scroll to top
