BT.com
Wishlist
StarTech.com 4 Port Wall Mount VGA Video Splitter
StarTech.com 4 Port Wall Mount VGA...
£40.71
1 in stock
£40.71
Add to wishlist
Delivery
Standard 3-5 working days
The ST124WGB 4 port wall-mountable VGA video splitter offers outstanding quality and distance, allowing you to deliver high resolution VGA video from a single video source to up to four monitors simultaneously.
Supporting a maximum VGA video bandwidth of up to 250MHz and resolutions up to 1600 x 1200, the device is sure to deliver on image quality. The wall-mountable multi-display VGA video splitter is very simple to install, allowing you to locate screens up to 65m (210ft) away from the VGA video source.
The video splitter provides versatile installation options, with top-side connection ports the unit can lay flat on or under your workspace, or you have the option to mount the splitter on a wall making it easy to position the VGA splitter as needed. A scalable video splitting solution, the device also allows you to cascade the signal using two additional splitters for broadcast from a single VGA source to up to 64 VGA monitors.
Typical applications of this product would include digital signage, retail and tradeshow environments, educational and government facilities, or corporate displays where high quality multi-monitor VGA video is required.
StarTech.com 4 Port Wall Mount VGA Video Splitter - video splitter - 4 ports
Video splitter - 4 ports - cascadable
Subtype
VGA
Ports
4 x VGA
Wall mountable
8.6 cm x 11.5 cm x 3.3 cm
150 g
Silver
United Kingdom
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
VGA
Ports
4 x VGA
Max Cascading Depth
3
Max Resolution
1920 x 1440 @ 75 Hz
Max Video Bandwidth
250 MHz
Wall mountable
Status Indicators
4 x VGA output - HD-15 , 1 x VGA input - HD-15
External power adapter
2.25 Watt
Silver
FCC, RoHS
United Kingdom
8.6 cm
11.5 cm
3.3 cm
150 g
50 °C
0 - 80%
Accessories
£16.69
£6.90
£11.46
Scroll to top
