BT.com
Wishlist
StarTech.com 4 Port SuperSpeed USB 3.0 VGA KVM Switch with Audio and Cables
StarTech.com 4 Port SuperSpeed USB...
£214.78
£214.78
Add to wishlist
Delivery
Standard Due date unavailable
Control 4 VGA, USB 3.0 equipped PCs with a single monitor, keyboard, mouse and audio peripheral set. The SV431U3A 4-Port USB 3.0 VGA KVM Switch lets you control 4 VGA, USB 3.0-equipped PCs with a single monitor, keyboard, mouse and audio peripheral set. For added convenience, the included KVM cables provide a ready-to-use KVM solution.
This USB 3.0 KVM Switch offers an integrated 2-port hub that supports USB 3.0 data rates up to 5 Gbps, and is backward compatible with USB 2.0 and 1.1/1.0 devices, ensuring flawless performance for your USB peripherals.
Offering support for high resolutions (up to 2048x1536), this 4-port VGA KVM switch has the ability to drive large VGA displays with ease, making it ideal for graphical applications that require high-res video output.
StarTech.com 4 Port SuperSpeed USB 3.0 VGA KVM Switch with Audio and Cables - KVM switch - 4 ports
KVM switch - 4 ports - USB
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
AC 120/230 V
10.2 cm x 26.5 cm x 4.5 cm
1 kg
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
Built-in Devices
USB 3.0 hub
Status Indicators
Port status
4 x USB 3.0 - Type B , 4 x VGA - HD-15 , 4 x audio / headphones - mini-jack , 4 x microphone input - mini-jack , 2 x USB 3.0 - Type A , 1 x VGA - HD-15 , 1 x audio / headphones - mini-jack , 1 x microphone input - mini-jack , 2 x keyboard (USB) / mouse (USB) - Type A
External power adapter
AC 120/230 V
4 x VGA cable , 4 x USB cable , 4 x audio cable
FCC, RoHS
10.2 cm
26.5 cm
4.5 cm
1 kg
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Accessories
£9.07
£4.23
Scroll to top
