BT.com
Wishlist
StarTech.com 4 Port PCI SATA RAID Controller Adapter Card
StarTech.com 4 Port PCI SATA RAID...
£31.96
£31.96
Add to wishlist
Delivery
Standard Due date unavailable
The PCISATA4R1 4 Port PCI SATA RAID Controller lets you add four internal SATA 1.0 (1.5 Gbps) ports to your PC through a single PCI expansion slot, while offering support for several RAID modes or a simple JBOD (Just a Bunch of Disks) configuration.
The PCI SATA card provides increased performance and capacity with RAID 0 (Striping), or a redundant copy of your hard drive with RAID 1 (Mirroring). Configuring in RAID 10 (a.k.a. RAID 0+1) lets you leverage both by creating a mirrored copy of your striped disk set. Plus, the SATA RAID card supports RAID 1+S (Mirror + Spare), which uses a third installed drive to automatically replace a failed drive and rebuild the mirrored set - even if it is the boot drive that failed.
For the ability to fit most standard computer cases, the card ships with a standard profile bracket installed and includes a low profile bracket for adapting to slimline or small form factor systems.
While the PCISATA4R1 card supports any size hard drive in JBOD mode, the max supported drive size when in RAID mode is 2 TB (per port).
StarTech.com 4 Port PCI SATA RAID Controller Adapter Card - storage controller (RAID) - SATA 1.5Gb/s - PCI-X
Storage controller (RAID) - plug-in card
Bus Type
PCI-X
SATA 1.5Gb/s
Data Transfer Rate
150 MBps
Supported Devices
Hard drive, disk array (RAID)
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10, JBOD, RAID 0+1
Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
4.5 cm x 12 cm x 2.2 cm
46 g
P/N: SATSASBAY3BK
Host Bus
PCI-X
Storage Controller
SATA 1.5Gb/s
Data Transfer Rate
150 MBps
Supported Devices
Channel Qty
4
RAID Level
4 x SATA 1.5Gb/s - 7 pin Serial ATA (internal)
Compatible Slots
1 x PCI-X
CSA, UL, TUV, CB
Limited warranty - lifetime
4.5 cm
12 cm
2.2 cm
46 g
P/N: SATSASBAY3BK
Other bundles
StarTech.com 4 Port PCI SATA RAID Controller Adapter...
£31.96
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.22
£35.18
Accessories
StarTech.com 24" Serial ATA Cable
Quicklinx: 3ZLH | In Stock
£4.27
StarTech.com 18" Serial ATA Cable w/R Angle
Quicklinx: 3ZLJ | In Stock
£4.23
£5.97
StarTech.com 18in SATA Serial ATA Cable
Quicklinx: 3ZLL | In Stock
£4.02
StarTech.com 36in SATA Serial ATA Cable
Quicklinx: 4KXJ | In Stock
£3.79
£4.27
£4.77
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Just works under Ubuntu Gutsy
Reviewed by Jim on 12/09/2008
Much easier than I was expecting. I'm running Ubuntu server 7.10 on an ancient 32 bit Athlon, Abit mobo with no SATA support - this card was detected by the kernel at first boot and presented my new drive on /dev/sda. Ten minute job, no pain whatsoever - penguin fans take note.
5* Might Save Someone Time ...
Reviewed by Alan T on 06/04/2007
Not explicitly stated in the BT summary of this product, I had to go looking on the StarTech site - so just in case someone else passes this way looking for this info .... Yes! you can just run your 4 SATA drives in JBOD mode (i.e. each drive stays separate). With one of these, and four 750GB SATA drives (see such a drive at quick linx 42L2WS) you could build a i/o subsystem that would provide the better part of 3 Terabytes (3000 Gbytes) with very good performance, for around £700!
5* Does what it says on the box, not the reviews
Reviewed by Anonymous on 11/12/2007
Great little card, however contrary to some of the reviews, note that it doesn't support RAID 5. I have downloaded the relevant BIOS update and drivers from the Silicon Image website, however windows doesn't allow the install of the drivers (I choose to update the driver for the card, and the RAID5 driver doesn't even appear in the list of options), nor does it allow the update of the card's BIOS through the control panel or the device manager (as described in the SI manual). So while it is an SiI3114 according to device manager, don't buy this expecting to be able to upgrade it to support RAID 5 (at least in hardware). This appears to be different from the BT value card, which people have said has been successfully updated to support RAID 5.
5* Perfect for Windows Home Servers
Reviewed by Paul on 05/09/2007
I installed 2 of these into one of my Windows Home Server machines, they are the perfect way to expand your system HDD capabilities.
5* It works
Reviewed by Mark on 15/03/2014
I brought and installed this card attached four hard drives too it, booted up my PC not expecting the hard drives to be found, but they was. Windows loaded I could see the drives and did not have to use the included CD to install anything else. So far so good, and I have eight hard drives in one machine.
5* Forget the GUI
Reviewed by TheBeeKeeper on 14/07/2008
With Windows XP first format the disks using Control Panel/Administrative Tools/Computer Management/Storage. I then found it best to forget the GUI application that comes on the CD and just set up the RAID 1 array using the DOS application accessed by pressing F4 during start-up. So much easier and quicker. To check it has worked, create the array, write a file to the new the combined drive and then re-boot and delete the array. When you re-boot again both drives should be visible with the same file on them. Delete the files (to be on the safe side) and then create the array again as before.
5* Revised review
Reviewed by Jonathan on 19/07/2008
I previously posted an incorrect review saying that the card did not work with Windows Server 2003. Well it does! (I think one of my PCI slots is broken). When working it is very simple to set up. A big bonus is that it does work with Windows Server 2003 as not many cheap four port cards say that they do.
5* PCI SATA / RAID Controller Card
Reviewed by Richard on 01/01/2011
Nice and Easy to configure.I have four SATA-II drives connected to the device, running a dual RAID-I (mirror) setup on a Fedora 14 Linux Server. The device automatically detects the drives connected and prompts for the type of RAID to be employed. The card can also simply be used as a device to provide extra SATA connectivity (minus the RAID). When creating the RAID-I setup, the device allows you to use a drive that already has the O/S installed (irrespective of whether it's Windows / Linux / etc) and gives you the option to mirror the contents straight away onto the blank drive - basically this means that you don't have to start with 2 blank drives. As mentioned I am running a dual RAID-I setup, one set is a RAID-I containing the Fedora 14 Operating System (During the O/S installation, Fedora immediately detected the controller card, and RAID setup), the other RAID-I setup contained the mirror for the data storage.
For such a cheap product it performs perfectly. Great stuff!
4* Having random read issues on OpenSuse11 X64
Reviewed by Pink on 12/12/2008
From what I have read, a few people seem to be having issues with this chipset (not just this startech card) under Linux. Problems vary from total lock up of the machine to drive incompatibilities.
My experience is one of having random read errors. Both my Linux X64 and my FreeBSD (x86) boxes suffer from random read issues. I bought 2 cards, not expecting that much based on the cheapness of the cards. Seems they write data fine.
But despite my problems it looks like a lot of users seem to have no problems with cards based on SiS 3114 chips, this one is no exception.
I've got to say good value for money, as long as it works for you.
I've tried various drives and they all suffer from the same problem, but are fine on the internal via controllers on my motherboards.
Easy to install.
Going to have to see if I can upgrade the firmware and hope that will fix the issues for me.
4* Troublesome at first but working fine now.
Reviewed by Ian on 12/07/2010
I initially had real problems with this card and two 750gb disks, the computer would freeze during or shortly after the bios screen when a disk was connected. This was caused by the card shipping with an ancient bios version which couldn't handle my new disks, and was solved by flashing the latest bios from Silicon Image's website (Startech themselves don't provide an updated bios so i had to get it directly from the chipset manufacturer's website). Working great now in Ubuntu 10.4 with a single raid-1 mirror.
Scroll to top
