BT.com
Wishlist
StarTech.com 4 Port PCI RS232 Serial Adapter Card High Speed 16950 cable included
Delivery
Standard Due date unavailable
Add 4 high-speed RS-232 serial ports to your computer with a buffered serial card from StarTech.com. The card uses a 16-Byte buffer in both the receive and transmit channels simultaneously, reducing the number of CPU interrupts and improving system performance. Compatible with both 3.3 and 5 volt motherboards, and uses DB9 connectors for use with a wide range of serial peripherals. Suitable for industrial applications, this card is compatible with a wide range of operating systems, including Windows, DOS, Linux, and Unix.
StarTech.com 4 Port PCI RS232 Serial Adapter Card High Speed 16950 cable included - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI
Ports
RS-232 x 4
RS-232
Data Transfer Rate
921.6 Kbps
SCO OpenServer, Microsoft Windows 95/98, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP
Serial adapter
Plug-in card
PCI
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
921.6 Kbps
4 x RS-232 - 9 pin D-Sub (DB-9) (on cable)
Compatible Slots
1 x PCI
1 x serial cable (external)
Limited warranty - lifetime
Accessories
£5.10
Scroll to top
