BT.com
Wishlist
StarTech.com 4 Port PCI Express Gigabit Ethernet NIC Network Adapter Card
Delivery
Standard Due date unavailable
Add four Gigabit network interfaces to a desktop PC or server with an available PCI Express x4 slot. The ST1000SPEX42 4-port Ethernet Card is an IEEE 802.3/u/ab standards compliant PCIe network adapter, which adds connections to up to four separate high-speed Gigabit networks from a single desktop client, server or workstation.
Suitable for any PCI Express (x4) enabled computer, this Gigabit Ethernet Network Adapter Card offers a practical, cost-effective resource for business, corporate or government environments, with support for high performance 4-channel networking and maximum throughput up to 1000Mbps in each direction (2000 Mbps total) - up to ten times faster than 10/100 Ethernet.
Compatible with a broad range of operating systems, this versatile PCIe Gigabit NIC is suitable for many SMB and Enterprise applications such as virtualized environments that require multiple NICs.
StarTech.com 4 Port PCI Express Gigabit Ethernet NIC Network Adapter Card - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
PCI Specification Revision
PCIe 1.1
Ports
Gigabit Ethernet x 4
10.2 cm x 14 cm x 1.8 cm
255 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7, Apple MacOS X 10.8, Windows 10 (32/64 bits)
2 years warranty
Network adapter
Plug-in card
PCI Express x4
PCIe 1.1
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
TCP/IP, UDP/IP
Status Indicators
Link OK, link/activity
Flow control, full duplex capability, auto-sensing per device, VLAN support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Jumbo Frames support
4 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express x4
FCC, RoHS
Software Included
Drivers & Utilities
10.2 cm
14 cm
1.8 cm
255 g
55 °C
5 - 95%
Accessories
StarTech.com 10' Cat5e Patch Cable Black
Quicklinx: 400G | In Stock
£3.97
£8.83
£3.85
£5.00
Scroll to top
