BT.com
Wishlist
StarTech.com 4 Port PCI 1394a FireWire Adapter Card with Digital Video Editing Kit
StarTech.com 4 Port PCI 1394a...
£16.39
43 in stock
£16.39
Add to wishlist
Delivery
Standard 3-5 working days
This 4 Port PCI IEEE 1394 FireWire 400 Adapter Card turns a motherboard PCI slot into four IEEE 1394a FireWire 6-pin female ports (1 internal, 3 external) - a cost-effective solution that lets you connect any FireWire 400 device that uses a 6-pin connector to your desktop computer.
The card can be installed in either Mac or PC computers, providing a practical solution for connecting iPods, MP3 players, portable drives, digital camcorders and more. The adapter card supports hot-swappable connectivity, allowing you to plug, unplug, and swap your FireWire peripherals with ease, saving time and hassle.
The 4 port FireWire PCI adapter card includes a copy of ULEAD's VideoStudio SE Basic video editing software, making it easy to capture and edit video from your digital video camcorder.
StarTech.com 4 Port PCI 1394a FireWire Adapter Card with Digital Video Editing Kit - FireWire adapter - 4 ports
FireWire adapter
Plug-in card
Interface (Bus) Type
PCI
Ports Qty
4 ports
Firewire
Data Transfer Rate
400 Mbps
Linux, Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 10 (32/64 bits)
Plug-in card
PCI
Wired
Firewire
Data Transfer Rate
400 Mbps
3 x FireWire - 6 PIN FireWire - 3 ( external ) , 1 x FireWire - 6 PIN FireWire - 1 ( internal )
Compatible Slots
1 x PCI
1 x IEEE 1394 cable ( external ) - 1.8 m
Software Included
Drivers & Utilities, Ulead VideoStudio SE Basic
Limited warranty - parts and labour - lifetime - carry-in
StarTech.com 4 Port PCI 1394a FireWire Adapter Card...
£16.39
Save on this ideal PC Build kit!
Save £16.90
£41.74
Accessories
£5.02
£5.10
£6.60
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Firewire Card IEEE-1394
Reviewed by Mr King on 06/03/2007
The IEEE-1394 Firewire Card is easy to use and is great because it comes with its own four pin cable to connect to most camcorders/digital camera's. Also comes with editing software dispite the fact I actually bought a newer version of the software that was included. Great value for money. No problems what so ever. Commend BT for speedy transaction and delivery. Highly Recommended.
5* Great Card
Reviewed by RS on 08/04/2008
Arrived in 24 hrs, installed in a couple of minutes, one minute to reboot my Dell XP machine and then I connected my DV camcorder (using the supplied firewire cable) and uploaded video. Perfect! Performance is better than the onboard IEEE-1394 on my HP desktop.
5* StarTech.com 4-Port IEEE-1394 PCI Firewire Card
Reviewed by Spoff on 18/02/2006
Excellent piece of hardware, easy to follow installation instructions. (This also includes a FireWire which wasn't apparent in description so I bought one of them also)
5* Brilliant
Reviewed by Bloggs on 23/09/2006
Slotted straight in, booted fine - no software to load (with XP), plugged in cable (supplied) to video camera and started transferring video - brilliant.
Scroll to top
