Click to visit BT.com
BT.com
Wishlist
StarTech.com 4 Port PCI 1394a FireWire Adapter Card with Digital Video Editing Kit
5.0*
Quicklinx: 2QFGWS00
Mfr#: PCI1394_4
Type: FireWire adapter
Compatibility: PC
Interface: PCI
Standard delivery Delivered within 3-5 working days
26 in stock
£14.89
This 4 Port PCI IEEE 1394 FireWire 400 Adapter Card turns a motherboard PCI slot into four IEEE 1394a FireWire 6-pin female ports (1 internal, 3 external) - a cost-effective solution that lets you connect any FireWire 400 device that uses a 6-pin connector to your desktop computer.
The card can be installed in either Mac or PC computers, providing a practical solution for connecting iPods, MP3 players, portable drives, digital camcorders and more. The adapter card supports hot-swappable connectivity, allowing you to plug, unplug, and swap your FireWire peripherals with ease, saving time and hassle.
The 4 port FireWire PCI adapter card includes a copy of ULEAD's VideoStudio SE Basic video editing software, making it easy to capture and edit video from your digital video camcorder.
StarTech.com 4 Port PCI 1394a FireWire Adapter Card with Digital Video Editing Kit - FireWire adapter - 4 ports
FireWire adapter
Plug-in card
Interface (Bus) Type
PCI
Ports Qty
4 ports
Firewire
Data Transfer Rate
400 Mbps
Linux, Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 10 (32/64 bits)
Plug-in card
PCI
Wired
Firewire
Data Transfer Rate
400 Mbps
3 x FireWire - 6 PIN FireWire - 3 ( external ) , 1 x FireWire - 6 PIN FireWire - 1 ( internal )
Compatible Slots
1 x PCI
1 x IEEE 1394 cable ( external ) - 1.8 m
Software Included
Drivers & Utilities, Ulead VideoStudio SE Basic
Limited warranty - parts and labour - lifetime - carry-in
StarTech.com 4 Port PCI 1394a FireWire Adapter Card with Digital Video Editing Kit Bundle deal on StarTech.com 4 Port PCI 1394a FireWire Adapter Card with Digital Video Editing Kit
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£34.42
saving £8.26
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£18.98
saving £1.39
2QFG StarTech.com 6ft IEEE-1394 FireWire Cable 6-6 M/M In Stock £5.02
2QFG StarTech.com 6 ft IEEE-1394 Firewire Cable 4-6 M/M In Stock £4.71
2QFG StarTech.com 10 ft IEEE-1394 FireWire Cable 6-6 M/M In Stock £6.22
2QFG StarTech.com IEEE-1394 FireWire Adapter 4 Pin - 6 Pin F/M In Stock £5.26
Customer reviews
Write a review for the StarTech.com 4 Port PCI 1394a FireWire Adapter Card with Digital Video Editing Kit here!
Firewire Card IEEE-1394
Reviewed by Mr King. Review Posted 06/03/2007
The IEEE-1394 Firewire Card is easy to use and is great because it comes with its own four pin cable to connect to most camcorders/digital camera's. Also comes with editing software dispite the fact I actually bought a newer version of the software that was included. Great value for money. No problems what so ever. Commend BT for speedy transaction and delivery. Highly Recommended.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Great Card
Reviewed by RS. Review Posted 08/04/2008
Arrived in 24 hrs, installed in a couple of minutes, one minute to reboot my Dell XP machine and then I connected my DV camcorder (using the supplied firewire cable) and uploaded video. Perfect! Performance is better than the onboard IEEE-1394 on my HP desktop.
  • Overall 5*
  • Ease of use 5*
StarTech.com 4-Port IEEE-1394 PCI Firewire Card
Reviewed by Spoff. Review Posted 18/02/2006
Excellent piece of hardware, easy to follow installation instructions. (This also includes a FireWire which wasn't apparent in description so I bought one of them also)
  • Overall 5*
  • Ease of use 5*
Brilliant
Reviewed by Bloggs. Review Posted 23/09/2006
Slotted straight in, booted fine - no software to load (with XP), plugged in cable (supplied) to video camera and started transferring video - brilliant.
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Compatibility: PC
Interface: PCI
Price Range Inc VAT: 0 - 50
