BT.com
Wishlist
StarTech.com 4 Port High Resolution VGA Video Splitter - 350 MHz
Delivery
Standard Due date unavailable
The StarTech.com VideoView Pro is a High-End 4 port VGA Video Splitter that allows a PC to display to as many as 4 monitors simultaneously. It is perfect for presentations, classrooms, tradeshows, or in-store displays where the highest quality video on several monitors is needed. The VideoView Pro supports monitors with up to 350MHz of bandwidth allowing it to display images of 2048 x 1536 pixels or higher. A built-in booster circuit allows the video signal to be extended up to 200 ft.
StarTech.com 4 Port High Resolution VGA Video Splitter - 350 MHz - video splitter - 4 ports
Video splitter - 4 ports
Subtype
VGA
Ports
4 x VGA
AC 230V
22.4 cm x 15.2 cm x 5.2 cm
1.2 kg
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
VGA
Ports
4 x VGA
Max Resolution
2048 x 1536 @ 80 Hz
Max Video Bandwidth
350 MHz
Status Indicators
Power, active
4 x VGA - HD-15 , 1 x VGA - HD-15
External power adapter
AC 230V
FCC Part 15
22.4 cm
15.2 cm
5.2 cm
1.2 kg
Accessories
£15.70
£57.19
£6.90
£11.46
Scroll to top
