BT.com
Wishlist
StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio
StarTech.com 4 Port High Resolution...
£296.82
Hurry, only 3 left in stock!
£296.82
Add to wishlist
Delivery
Standard 1-3 working days
This 4 Port Dual Link DVI USB KVM Switch provides simple, yet comprehensive control of up to four directly connected computers as well as audio switching capability and support for high resolution applications (supports 1080p, and up to 2560x1600 @ 60Hz, up to 3840 x 2400 at lower refresh rates, and Apple Cinema quality resolutions) - a superior switching solution that integrates perfectly into multimedia environments.
The DVI USB KVM Switch is compatible with all USB supported operating systems, and features a built-in USB 2.0 hub that allows you to share up to three high speed USB devices between computers.
StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio - KVM / audio / USB switch - 4 ports
KVM / audio / USB switch - 4 ports - cascadable
Enclosure Type
1U
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
22 cm x 13 cm x 4.4 cm
1.8 kg
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600 @ 60 Hz
Built-in Devices
USB Hub
Status Indicators
Port status
4 x USB 2.0 - Type B , 4 x DVI-I (dual link) , 4 x audio output - mini-jack , 4 x microphone input - mini-jack , 1 x keyboard (USB) - Type A , 1 x mouse (USB) - Type A , 1 x DVI-I (dual link) , 2 x USB 2.0 - Type A , 1 x audio output - mini-jack , 1 x microphone input - mini-jack
External power adapter
Rack Mounting Kit
Optional
FCC, RoHS
22 cm
13 cm
4.4 cm
1.8 kg
Limited warranty - 3 years
Accessories
£7.58
£9.70
£9.70
Scroll to top
