BT.com
Wishlist
StarTech.com 4-Port HDMI Switch with Picture-and-Picture Multiviewer
StarTech.com 4-Port HDMI Switch...
£1,158.72
Hurry, only 3 left in stock!
£1,158.72
Add to wishlist
Delivery
Standard 1-3 working days
Share an HDMI display between four distinct HDMI audio/video sources, with optional Picture-and-Picture. The VS421HDPIP 4-Port HDMI Video Switch with Picture-and-Picture (PAP) lets you connect four HDMI video sources to a single HDMI display with the added benefit of playing all four video sources on your display simultaneously with combined video.
The split-screen multiplexing switch gives you the flexibility of a 4-port video switch with the added benefit of combining two, three or four video sources onto your output display. The switch supports three different picture-and-picture modes per display: Matrix Mode (1x1) / Dual Mode (2x1) / Quad Mode (4x1).
Fitting your boardroom or digital signage application with a VS421HDPIP dramatically increases your communication possibilities. Not only does the picture-and-picture switch increase your communication by a factor of four, but it also enables you to adjust your video sources remotely using RS232 serial, your local TCP/IP network, or the included IR remote control.
The VS421HDPIP is a flexible video switch that can improve any video display application. The picture-and-picture technology enables you to share up to four distinct images on the same screen, reducing required video real estate and saving you from wasting money on additional displays in a digital signage applications. For security monitoring you can combine four video sources across a single display to view everything more efficiently - you can even zoom into a single feed for a closer look. For versatile installation options mounting hardware is also included ensuring a tidy professional installation.
StarTech.com 4-Port HDMI Switch with PIP - video splitter - 4 ports
Video splitter - 4 ports
Subtype
HDMI
Ports
4 x HDMI
AC 120/230 V
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
HDMI
Ports
4 x HDMI
4 x HDMI
External power adapter
AC 120/230 V
FCC, RoHS
Accessories
£9.90
£7.21
£13.20
Scroll to top
