BT.com
Wishlist
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub
StarTech.com 4 Port DVI VGA Dual...
£239.77
20 in stock
£239.77
Add to wishlist
Delivery
Standard 1-3 working days
The SV431DDVDUA 4-port DVI VGA dual monitor KVM switch lets you control 4 Dual Display computers using a single USB mouse and keyboard peripheral set.
This dual view KVM switch provides 1 VGA and 1 DVI-I port per computer connection for high-resolution video, as well as audio switching capability between connected computers.
The DVI/VGA KVM switch features an integrated 2-port USB hub that allows USB 2.0 peripherals to be shared between connected computers, and offers a compact design with a rugged metal chassis for durable performance.
While both DVI-I (analog) and DVI-D (digital) are supported by the KVM, source PCs must output the same signal for proper switching. It is recommended wherever possible to use DVI-D cables across all PC to KVM and KVM to Console connections.
StarTech.com StarView 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub - KVM / audio / USB switch - 4 ports
KVM / audio / USB switch - 4 ports - USB
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2 port USB 2.0 hub, HDCP compliant
22 cm x 13 cm x 6 cm
1.2 kg
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
1 x VGA - HD-15 , 1 x DVI-D , 4 x USB 2.0 - Type A , 2 x audio - mini-jack , 4 x VGA - HD-15 , 4 x DVI-D , 4 x audio - mini-jack , 4 x USB 2.0 - Type B
External power adapter
FCC, RoHS
22 cm
13 cm
6 cm
1.2 kg
Limited warranty - 3 years
Accessories
StarTech.com 6ft High Speed USB 2.0 Cable
Quicklinx: 2ZWQ | In Stock
£3.79
£5.20
£4.58
£3.79
£14.24
Scroll to top
