BT.com
Wishlist
StarTech.com 4 Port DVI USB KVM Switch with Dual DVI Console
StarTech.com 4 Port DVI USB KVM...
£1,819.84
Hurry, only 1 left in stock!
£1,819.84
Add to wishlist
Delivery
Standard 1-3 working days
Control 4 systems using a single peripheral set, with dual DVI console connections and multiple picture-in-picture display modes. The SV431DVIUAQV 4-Port DVI KVM Switch with Quad-View Display lets you control 4 systems using a single peripheral set, with dual DVI console connections and multiple picture-in-picture display modes.
The DVI USB KVM features an integrated 2-port USB 2.0 hub for connecting additional peripherals to share, plus StarTech.com has included the necessary DVI, USB and audio cables for a ready-to-use solution.
The Quad-View function integrates a quad screen splitter into the KVM switch to offer several picture-in picture display modes so you can monitor some or all of the connected PCs on the primary console display while interacting with the active PC on the secondary display. Choose from: Quad-View: Displays all 4 connected PCs simultaneously; Picture-and-Picture (PAP): Displays the active PC in the main display area and 3 others along the right side; Picture-in-Picture (PIP): Displays the active PC in the main display area and 1 other in a movable and sizeable PIP window; Full-View: Displays the active PC on both of the console displays.
The KVM switch integrates front, push-button controls for simple switching between PCs, choosing your desired display mode and accessing the KVM menu, plus hot-keys and RS-232 command support, for flexible control.
For added versatility, you can daisy-chain up to 8 SV431DVIUAQV units total, for control of up to 32 PCs using a single peripheral set.
StarTech.com 4 Port DVI USB KVM Switch with Dual DVI Console and Quad-View - KVM / audio / USB switch - 4 ports - rack-mountable
KVM / audio / USB switch - 4 ports - USB - cascadable
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
On-Screen Display, built-in 2 port USB 2.0 hub, Picture in Picture function, Picture and Picture function
AC 120/230 V
43.8 cm x 20 cm x 4.4 cm
5.6 kg
2 years warranty
Bundled Services
2 years warranty
KVM / audio / USB switch - 4 ports - cascadable
Enclosure Type
Desktop, rack-mountable 1U
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Cascading Depth
8
Max Resolution
1920 x 1200
1 x keyboard (USB) - Type A , 1 x mouse (USB) - Type A , 2 x DVI-I , 1 x audio - mini-jack , 4 x USB - Type B , 4 x audio - mini-jack , 4 x DVI-I , 2 x serial (RS-232) - RJ-45 , 2 x USB 2.0 - Type A
External power adapter
AC 120/230 V
4 x DVI cable , 4 x USB cable , 4 x audio cable
Rack Mounting Kit
Included
FCC, RoHS
43.8 cm
20 cm
4.4 cm
5.6 kg
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Accessories
£10.71
£4.72
£4.35
Scroll to top
