BT.com
Wishlist
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub
StarTech.com 4 Port Dual DVI USB...
£307.78
13 in stock
£307.78
Add to wishlist
Delivery
Standard 1-3 working days
Share a keyboard, mouse and dual DVI displays/monitors between 4 multimedia computers. The SV431DD2DUA 4-port Dual DVI USB KVM Switch allows up to four PCs, each with dual DVI video outputs, to share two monitors, one microphone and set of speakers, one keyboard and one mouse as well as two other USB peripherals.
An ideal solution for graphic designers, CAD/CAM designers or educational and financial institutions, the dual view KVM Switch allows you to instantly switch back and forth between dual DVI display PCs at the touch of a button, while maintaining professional level video quality on both monitors. The dual DVI switch also features an integrated USB hub port that allows USB 2.0 peripherals such as thumb drives, external hard drives or web cams to be shared between attached systems - eliminating duplicate peripheral costs.
While both DVI-I (analog mode) and DVI-D (digital only) are supported by the KVM, both source PCs should output the same signal type for proper switching. It is recommended wherever possible to use DVI-D cables across all PC to KVM and KVM to Console connections.
StarTech.com 4 Port Dual DVI USB KVM Switch w/ Audio & USB Hub - KVM / audio / USB switch - 4 ports
KVM / audio / USB switch - 4 ports - USB
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2 port USB 2.0 hub
22 cm x 13 cm x 6 cm
1.2 kg
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
8 x DVI-I , 4 x keyboard (USB) / mouse (USB) - Type B , 4 x microphone - mini-jack , 4 x speakers - mini-jack , 2 x DVI-I , 1 x microphone - mini-jack , 1 x speakers - mini-jack , 2 x keyboard (USB) / mouse (USB) - Type A , 2 x USB 2.0 - Type A
External power adapter
FCC, RoHS
22 cm
13 cm
6 cm
1.2 kg
Limited warranty - 3 years
Accessories
StarTech.com 6ft High Speed USB 2.0 Cable
Quicklinx: 2ZWQ | In Stock
£3.79
£8.72
£5.20
£4.58
£3.79
£13.60
£11.40
Scroll to top
