BT.com
Wishlist
StarTech.com 4 Port Black USB 2.0 Hub
StarTech.com 4 Port Black USB 2.0...
£16.28
More than 50 in stock
£16.28
Add to wishlist
Delivery
Standard 3-5 working days
Turn a single USB 2.0 port into 4 external USB 2.0 ports.
This 4 Port USB 2.0 Hub connects to one USB 2.0 port on a Mac or PC computer, adding four USB 2.0 ports - allowing you to maximize the number of high speed USB peripherals connected to your computer. The hub supports cascaded installation with other USB 2.0 hubs, supporting up to 127 USB 2.0 device connections - a scalable solution for connecting multiple USB devices to a single host computer.
The 4 port hub includes a power adapter, but can be powered through USB bus connection to the host computer - allowing you to install the hub as needed without worrying about the availability of a power outlet.
The USB 2.0 hub offers an attractive black casing that suits any operating environment and includes a 3ft USB 2.0 A/B male-male cable, for the connection between the hub and the host computer.
StarTech.com 4 Port Compact Black USB 2.0 Hub - hub - 4 ports - desktop
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
USB 1.1, USB 2.0
6.8 cm x 9.7 cm x 1.9 cm
Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003
United Kingdom
1 year warranty
Bundled Services
1 year warranty
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
USB 1.1, USB 2.0
Status Indicators
4 x USB 2.0 - Type A , 1 x USB 2.0 - Type B
External power adapter
1 x USB cable - 91 cm
Plug and Play, FCC, RoHS
United Kingdom
Software Included
Drivers & Utilities
6.8 cm
9.7 cm
1.9 cm
Limited warranty - 1 year
70 °C
Accessories
StarTech.com 6ft High Speed USB 2.0 Cable
Quicklinx: 2ZWQ | In Stock
£3.87
£5.20
£4.58
£3.79
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Backfeeds power
Reviewed by Sam on 08/01/2013
If all you need is a hub to plug in to your PC, and aren't particularly in need of a powered one, these will do the job.
Having said that I've had a couple of these now and 3 of 4 have failed in various ways. I sent two back when they failed and got replacements, one of which also broke so I've given up. However, my application is a little specialist and not as forgiving to cheap equipment as a PC would be.
Also, with the PSU plugged in they backfeed power, ie power from the PSU will be fed to the PC. This should not affect a PC which will be protected, however could be useful if you want a hub to power your Raspberry Pi ;)
Scroll to top
