BT.com
Wishlist
StarTech.com 4 Drive 2.5in Removable SAS SATA Mobile Rack Backplane
Delivery
Standard Due date unavailable
Install four 2.5in SAS/SATA Hard Drives into one 5.25in Bay. The SATSASBAY425 Removable SAS and SATA Backplane/Mobile Rack offers a convenient and efficient way to maximize the storage density of your PC or Server when drive bay space is limited.
The backplane can house up to four 2.5" SAS or SATA removable hard drives (HDD) or solid state drives (SSD) (9.5mm, 12.5mm, or 14.8mm thick) in a single 5.25in drive bay, while supporting high speed data transfer rates up to 6 Gbps - a compact, RAID-compatible storage solution.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
To help dissipate operating heat, the SAS/SATA backplane features a sturdy aluminum casing that also helps to protect drives and valuable data from in-transit damage.
StarTech.com 4 Drive 2.5in Removable SAS SATA Mobile Rack Backplane - storage enclosure
Storage enclosure
4 (max)
Supported Drives
SATA-300 / SAS
Hard Drive
0 HDD SATA 3Gb/s / SAS - hot-swap
14.6 cm x 17.5 cm x 4.2 cm
0.79 kg
2 years warranty
P/N: PEXSAT34RH
Storage enclosure
Enclosure Colour
Chassis
Supported Devices / Modules Qty
4
Supported Drives
SATA-300 / SAS
Hard Drive
HDD - hot-swap
0
Interface Type
SATA 3Gb/s / SAS
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5"
4 x SATA 3Gb/s - 7 pin Serial ATA
Mounting Kit
Included
MTBF
20,000 hours
Plug and Play, FCC, RoHS
14.6 cm
17.5 cm
4.2 cm
0.79 kg
-10 °C
70 °C
5 - 90%
P/N: PEXSAT34RH
Accessories
StarTech.com 18in SATA Serial ATA Cable
Quicklinx: 3ZLL | In Stock
£4.02
StarTech.com 36in SATA Serial ATA Cable
Quicklinx: 4KXJ | In Stock
£3.79
StarTech.com 12in Latching SATA Cable
Quicklinx: 4LSN | In Stock
£4.00
StarTech.com 18in Latching SATA Cable
Quicklinx: 4LTJ | In Stock
£4.47
£5.22
£6.15
£5.44
Scroll to top
