BT.com
Wishlist
StarTech.com 3m DVI-D Dual Link Monitor Extension Cable - M/F
Delivery
Standard Due date unavailable
Extend the connection distance between your DVI-D digital devices by 3 meters. The DVIDDMF3M 3m DVI-D Dual Link Extension Cable allows you to extend the connection between your desktop workstation and DVI monitor, or your laptop and projector by up to 3-meters.
The dual link cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
This durable DVI male to female cable is designed to provide a high quality digital video experience.
StarTech.com 3m DVID Dual Link Monitor Extension Cable M/F - DVI extension cable - 3 m
DVI extension cable - dual link
Thumbscrews, ferrite bead
Length
3 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
RoHS
DVI extension cable
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Plated Connector
Nickel
Length
3 m
Connector
24+1 pin digital DVI - male
24+1 pin digital DVI - female
RoHS
Scroll to top
