BT.com
Wishlist
StarTech.com 36in SATA Serial ATA Cable
StarTech.com 36in SATA Serial ATA...
£3.79
Hurry, only 2 left in stock!
£3.79
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Connect and position SATA drives easily - designed for larger cases. The SATA36 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 36in SATA Serial ATA Cable - SATA cable - 0.9 m
SATA cable
Interface Speed
Serial ATA 150
Length
0.9 m
Connectors
1 x 7 pin Serial ATA - female
Connectors (Other Side)
Red
P/N: PEXSAT31E1, SATSASBAY425, PEXSAT32, BRACKET25SAT, SAT2510U2S, PEXSATA22I, PEXSAT2IDE2, SAT2510U2REM, PCISAT2IDE1, SATABAY5BK, SATABAY3BK, SATABAY4BK, PCISATA4R1
Storage Cable Type
SATA cable
Interface Speed
Serial ATA 150
Length
0.9 m
Red
Colour Category
Red
Connectors
StarTech.com 1x eSATA + 1x SATA 6Gbps PCI Express SATA Controller Card, 2 Port SATA 6 Gbps PCI Express SATA Controller Card, 2.5in SATA External Hard Drive Enclosure for 3.5/5.25 Front Drive Bay, 2S1I PCI SATA IDE Combo Controller Adapter Card, 2S2I PCI Express SATA IDE Combo Controller Adapter Card, 3 Drive 3.5in SATA Hot Swap Hard Drive Backplane with RAID, 4 Drive 2.5in Removable SAS SATA Mobile Rack Backplane, 4 Drive 3.5in Hot Swap SATA Mobile Rack Backplane, 4 Port PCI SATA RAID Controller Adapter Card, Extra 2.5in SATA Hard Drive Enclosure for SAT2510U2REM
Scroll to top
