Click to visit BT.com
BT.com
Wishlist
StarTech.com 30in MPC2 CD-ROM Audio Cable - F/F
Quicklinx: 3ZM3WS00
Mfr#: CDAUDIO2
Length: 76.2cm
Type: Audio
Standard delivery Delivered within 3-5 working days
14 in stock
£3.14
Only best-quality components are used when StarTech.com's expert manufacturing team creates its cabling and this cable is not different. The 30-inch MPC2 CD-ROM audio cable will let you connect a CD-ROM audio output to a sound card. Cables help StarTech.com maintain its tradition of offering top-notch parts and products for the best price possible.
StarTech.com 30in MPC2 CD-ROM Audio Cable - F/F - audio cable - 76.2 cm
Audio cable
Length
76.2 cm
Connectors
1 x 4 PIN MPC - female
Connectors (Other Side)
P/N: PCISOUND4LP, PCISOUND5CH, PCISOUND4CH
Audio cable
Length
76.2 cm
Connectors
StarTech.com 4 Channel Low Profile PCI Sound Adapter Card AC97 3D Audio Effects, 5 Channel PCI Sound Adapter Card with AC97 3D Audio Effects
StarTech.com 30in MPC2 CD-ROM Audio Cable - F/F Bundle deal on StarTech.com 30in MPC2 CD-ROM Audio Cable - F/F
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£7.23
saving £1.39
Length: 76.2cm
Type: Audio
Price Range Inc VAT: 0 - 50
