BT.com
Wishlist
StarTech.com 30in MPC2 CD-ROM Audio Cable - F/F
StarTech.com 30in MPC2 CD-ROM Audio...
£3.18
39 in stock
£3.18
Add to wishlist
Delivery
Standard 3-5 working days
Only best-quality components are used when StarTech.com's expert manufacturing team creates its cabling and this cable is not different. The 30-inch MPC2 CD-ROM audio cable will let you connect a CD-ROM audio output to a sound card. Cables help StarTech.com maintain its tradition of offering top-notch parts and products for the best price possible.
StarTech.com 30in MPC2 CD-ROM Audio Cable - F/F - audio cable - 76.2 cm
Audio cable
Length
76.2 cm
Connector
MPC - female
Connector (Second End)
MPC - female
P/N: PCISOUND4LP, PCISOUND5CH, PCISOUND4CH
Audio cable
Length
76.2 cm
Connector
4 pin MPC - female
4 pin MPC - female
StarTech.com 4 Channel Low Profile PCI Sound Adapter Card AC97 3D Audio Effects, 5 Channel PCI Sound Adapter Card with AC97 3D Audio Effects
Scroll to top
