BT.com
Wishlist
StarTech.com 3-Port IEEE-1394 Notebook Firewire Card
Delivery
Standard Due date unavailable
This 3 Port PCMCIA IEEE 1394 FireWire 400 Laptop Adapter Card allows you to connect FireWire/i.LINK devices such as iPods or DV (digital video) camcorders to your laptop computer through a CardBus slot.
Compatible with both PC and Mac laptop computers, the adapter card supports hot-swapping FireWire device connections, allowing you to unplug and swap peripherals with ease.
The adapter card includes a 5ft FireWire cable as well as a copy of ULEAD's VideoStudio SE Basic video editing software, making it easy to capture and edit video on your notebook computer, directly from your digital video camcorder.
StarTech.com 3 Port CardBus 1394a FireWire Adapter Card - Digital Video Editing Kit - FireWire adapter
FireWire adapter
Plug-in card
Interface (Bus) Type
CardBus
Ports
FireWire x 3
8.6 cm x 5.4 cm x 0.5 cm
0.2 kg
Firewire
Data Transfer Rate
400 Mbps
Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Microsoft Windows XP
P/N: CB2EC, PCI2PCMCIA1E, PCI2PCMCIA2, PCI2PCMCIA1
FireWire adapter
Plug-in card
CardBus
Ports
FireWire x 3
Wired
Firewire
Data Transfer Rate
400 Mbps
3 x FireWire - 6 PIN FireWire - 3
Compatible Slots
1 x CardBus
1 x IEEE 1394 cable ( external ) - 1.8 m
Plug and Play
Software Included
Drivers & Utilities, Ulead VideoStudio SE
8.6 cm
5.4 cm
0.5 cm
0.2 kg
Service & Support Details
Limited warranty - parts and labour - lifetime
StarTech.com 1 Port PCI to CardBus PCMCIA Adapter Card, 2 Port PCI to CardBus PCMCIA Adapter Card - Dual Profile, CardBus/PCMCIA to PCI Adapter Card, ExpressCard to CardBus Laptop Adapter PC Card
Accessories
£5.02
£4.93
£6.60
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* do noy buy for use with ipod
Reviewed by on 17/06/2004
I bought this with a view to using it with my Ipod. I soon discovered by mailing techsupport that it is not designed for this.
So i have a card which is useless to me. Do not buy thinking you can use this for charging and syncing an ipod because it is a firewire card of sorts.
3*
Reviewed by Anonymous on 29/06/2004
This card looks the ticket with 3 ports and a great price and editing software etc, etc....but it actually damaged hundreds of avi files on my external firewire/usb drive. I am returning it for a more expencive make in the hope that a more relaible make will work better. Buyers Beware!!!
Scroll to top
