BT.com
Wishlist
StarTech.com 3 ft SuperSpeed USB 3.0 to eSATA Cable Adapter
Delivery
Standard Due date unavailable
The USB3S2ESATA USB 3.0 to eSATA Adapter Cable lets you connect an external SATA (eSATA) device or enclosure to a host computer through USB 3.0, in a single convenient package. The adapter cable combines USB 3.0 and eSATA cables into an integrated cable, with no external power source or driver installation required, for simple and hassle-free installation - No assembly or searching for the right cable required.
With support for SuperSpeed USB 3.0 connectivity at transfer rates up to 5 Gbps (10 times faster than USB 2.0), and backward compatibility with USB 2.0, the USB 3.0 to eSATA adapter cable provides a fast and easy-to-use Plug-and-Play experience for home, office or laptop users alike.
StarTech.com SuperSpeed USB 3.0 to eSATA Cable Adapter - storage controller - eSATA 3Gb/s - USB 3.0
Storage controller - external
Bus Type
USB 3.0
eSATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Max Storage Devices Qty
1
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7, Apple MacOS X 10.2.x - 10.6.x
77 g
2 years warranty
P/N: USB3S2SATA
Host Bus
USB 3.0
Storage Controller
eSATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
1
1 x eSATA 3Gb/s - 7 pin external Serial ATA
1 x USB 3.0 - 9 pin USB Type A
1 x USB cable - external
FCC, RoHS
Limited warranty - 2 years , Technical support - lifetime
77 g
50 °C
5 - 85%
StarTech.com SuperSpeed USB 3.0 SATA Adapter Cable for 2.5in or 3.5in Hard Drives
Accessories
£28.60
Scroll to top
