BT.com
Wishlist
StarTech.com 3 ft Shielded External eSATA Cable M/M
StarTech.com 3 ft Shielded External...
£8.23
More than 50 in stock
£8.23
Add to wishlist
Delivery
Standard 3-5 working days
Startech.com's high performance shielded eSATA cables allow you to take advantage of the benefits the SATA interface brings to storage, and use them in your external connections. Perfect for connections to external storage and backup devices, as well as with notebooks and servers.
StarTech.com Shielded External eSATA Cable - eSATA cable - 91 cm
eSATA cable
Interface Speed
Serial ATA 150
Length
91 cm
Connector
7 pin external Serial ATA - male
Connector (Second End)
P/N: PEXSAT31E1, S2510PESAT, PEXESAT32, ECESAT32, SAT3540ER, USB2ESATA, SAT3540ERGB, 35BAYPANELBK, PEXESATA2I, PEXESATA1, SAT5210U2EGB, SAT5210U2E, SAT2510U2E, PEXESATA2, CBESATA2, ECESATA22, SAT3510U2E, ESATCASE2
Storage Cable Type
eSATA cable
Interface Speed
Serial ATA 150
Length
91 cm
Connector
StarTech.com 1 Port eSATA + 1 Port SATA PCI Express SATA Controller Card, 1 Port PCI Express eSATA Controller Card, 1x eSATA + 1x SATA 6Gbps PCI Express SATA Controller Card, 2 Port CardBus eSATA Laptop Adapter Card, 2 Port ExpressCard eSATA Controller Adapter Card, 2 Port SATA 6 Gbps ExpressCard eSATA Controller Card, 2 Port SATA 6 Gbps PCI Express eSATA Controller Card, 2.5in eSATA USB External Hard Drive Enclosure for SATA HDD, 2.5in Silver Power eSATA to SATA External Hard Drive Enclosure w/ OTB, 3.5in Black Multi Port Panel for Front Drive Bay, 3.5in Silver 4 Drive eSATA Multi RAID External Hard Drive Enclosure, USB 2.0 to eSATA Adapter , StarTech.com InfoSafe 3.5" eSATA & USB 2.0 SATA Drive Enclosure, 5.25" eSATA/USB 2.0 SATA Optical Drive Enclosure, Dual 3.5" Drive eSATA to SATA HD Enclosure
Scroll to top
