Click to visit BT.com
BT.com
Wishlist
StarTech.com 3 ft Power eSATA Cable - M/M
Quicklinx: 6PFGWS00
Mfr#: ESATAUSB3
Length: 91cm
Express delivery Order within the next 18 hours for delivery on Monday
Hurry, only 3 left in stock!
£7.89
This 3 ft eSATA + USB Cable features two male eSATA/USB combo connectors, allowing you make a direct link between devices equipped with USB and eSATA combination ports.
An ideal solution for connecting external hard drive enclosures to your laptop or desktop computer, this high quality cable provides a full speed eSATA connection combined with a USB connection that can be used to power the external storage (where supported) - even if using a laptop computer running on battery power.
StarTech.com 3 ft Power eSATA Cable - M/M - Power Over eSATA cable - 91 cm
Length
91 cm
Connectors
1 x 11 pin USB/eSATA - male
Connectors (Other Side)
StarTech.com 2.5in Silver Power eSATA to SATA External Hard Drive Enclosure w/ OTB
Storage Cable Type
Length
91 cm
Colour Category
Connectors
RoHS
StarTech.com 3 ft Power eSATA Cable - M/M Bundle deal on StarTech.com 3 ft Power eSATA Cable - M/M
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£17.88
Length: 91cm
Price Range Inc VAT: 0 - 50
