BT.com
Wishlist
StarTech.com 3.5in SATA to CompactFlash SSD Adapter Card for 3.5 Drive Bay
Delivery
Standard Due date unavailable
This 3.5in SATA to CompactFlash SSD Adapter Card allows you to connect a CompactFlash card to a host computer through a Serial ATA data port - a cost-effective solution that lets you use solid state storage in place of a SATA hard disk drive.
The adapter includes a 3.5in bracket that lets you mount it in the front or rear panel of the computer case, suitable for any 3.5in drive bay or available expansion slot - providing easy access to the CF slot. Once the adapter is installed in the computer, the CompactFlash card can be used as an ejectable, bootable drive - providing full read and write access to the CF card, as if it were a SATA hard drive.
StarTech.com 3.5in SATA to CompactFlash SSD Adapter Card for 3.5 Drive Bay - card reader - Serial ATA
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Microdrive
Host Interface
Serial ATA
Required Bay
3.5" internal
1 year warranty
Host Interface
Serial ATA
Required Bay
3.5" internal
Required Ports
1 x 7 pin Serial ATA
3.5-inch bay adapter, rear expansion slot bracket
FCC, RoHS
Limited warranty - 1 year
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* Beware !
Reviewed by Anonymous on 28/06/2011
I have a large number of CF cards full of images and need to be able to swap cards on a regular basis.
Only after buying This card did I discover that it does not support "hot-swapping" - you have to switch off and reboot in order to change cards. I think the site needs to warn potential purchasers that this is the case.
I returned the card unused.
Scroll to top
