BT.com
Wishlist
StarTech.com 3.5in eSATA USB Dual Removable SATA RAID Enclosure
Delivery
Standard Due date unavailable
Turn two SATA drives into a removable external storage device with USB 2.0 and eSATA connectivity. This eSATA/USB external dual SATA hot-swap hard drive enclosure lets you install two 3.5in SATA (SATA, SATA II, SATA III) drives with support for a broad range of RAID applications including RAID 0, RAID 1, BIG, JBOD, SAFE33 & SAFE50.
Delivering maximum versatility, the dual SATA external hard drive enclosure can be connected to a computer using either eSATA or USB 2.0, and features built-in port multiplier support that allows both of the installed SATA hard drives to be connected using a single eSATA connection to your computer (port multiplier capable eSATA host controller required).
The hot-swappable trays allow you to quickly remove and install hard drives without having to reboot or disconnect the drive enclosure. Plus, the dual SATA hard drive enclosure offers built-in RAID support, which will rebuild the RAID array in the event a new drive is inserted - providing seamless uninterrupted communication with your PC and data.
The eSATA USB dual SATA HDD enclosure features a sturdy and attractive silver aluminum casing that looks great in any environment and helps protect installed SATA hard drives and their valuable data content from in-transit damage, while providing maximum heat dissipation.
Using Terabyte hard drives? Don't expose your hard drive and valuable data to unnecessary heat! StarTech.com's eSATA/USB external dual SATA hot-swap hard drive enclosure includes a large, built-in 50mm fan that re-distributes the heat build-up that's generated as a result of typical drive operation, which is especially important when using high capacity hard drives, and faster "spinning" drives (i.e 7200 RPM), as it can help keep drives running cooler, which can preserve data integrity and the drive's lifespan by reducing the chances of premature failures.
StarTech.com 3.5in eSATA USB Dual Removable SATA RAID External Hard Drive Enclosure - hard drive array
Hard drive array
Max Supported Capacity
4 TB
USB 2.0, SATA 3Gb/s
0 (installed) / 2 (max)
Supported Drives
SATA-300
Storage Controller
RAID (SATA 3Gb/s) - RAID 0, 1, JBOD, SAFE33, SAFE50
Hard Drive
0 HDD SATA 3Gb/s - hot-swap
AC 120/230 V - 50/60 Hz
10 cm x 23.3 cm x 14 cm
2 kg
1 year warranty
Hard drive array
Enclosure Colour
Silver
Chassis
0
Supported Devices / Modules Qty
2
Supported Drives
SATA-300
Storage
4 TB
HDD Array External Interface
USB 2.0, SATA 3Gb/s
SiI5744
Storage Controller
RAID - integrated (USB 2.0 / eSATA 3Gb/s)
Channel Qty
2
Interface Type
SATA 3Gb/s
Supported Devices
Hard drive
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD, SAFE33, SAFE50
Hard Drive
HDD - hot-swap
0
Interface Type
SATA 3Gb/s
Expansion Bays
2 (total) / 2 (free) x hot-swap - 3.5"
1 x USB 2.0 - 4 pin USB Type B , 1 x eSATA 3Gb/s - 7 pin external Serial ATA
UL, FCC, RoHS
External power adapter
10 cm
23.3 cm
14 cm
2 kg
Limited warranty - 1 year
70 °C
10 - 90%
Scroll to top
