BT.com
Wishlist
StarTech.com 3.5" Bay Removable 2.5 SATA Drive Enclosure
Delivery
Standard Due date unavailable
Turn any 2.5in SATA hard drive into both an internal removable hard drive or a USB 2.0 external hard drive. This 2.5in SATA External Hard Drive Enclosure lets you turn any 2.5in Serial ATA hard drive (HDD) or solid state drive (SSD) into a dual purpose, internal removable hard drive.
Perfect for large volume data offloads, digital video recording, surveillance, audio editing (no fan so noiseless), external storage, or a simple way to swap storage between your notebook and desktop computers, the external hard drive enclosure is easy to install and use. Simply install the provided drive bracket & bay into any 5.25in or 3.5in drive bay on the host computer and connect the bay to the computer SATA port. Then, install the 2.5in SATA hard drive in the external enclosure, and insert the enclosure into the 5.25in/3.5in bay for instant connectivity with the host computer!
The hard drive enclosure is ejectable, and supports standalone installation, letting you connect the enclosure to any computer through a USB 2.0 port. The enclosure supports high capacity drives in a 9.5mm height form factor.
For even more versatility, StarTech.com offers Extra 2.5in SATA Hard Drive Enclosures for the SAT2510U2REM, providing multiple enclosures that can be swapped in and out of the main computer.
StarTech.com 2.5in SATA External Hard Drive Enclosure for 3.5/5.25 Front Drive Bay - storage enclosure - SATA 3Gb/s - SATA 3Gb/s, USB 2.0
Storage enclosure - external
Bus Type
SATA 3Gb/s, USB 2.0
Expansion Bays
1 x internal - 2.5" x 1/8H
Compatible Bay
1 3.5" x 1/3H
Hard Drive Form Factor Compatibility
2.5"
Supported Interface
SATA 3 Gb/s
Drive Connector
7 pin Serial ATA
Bay Connector
7 pin Serial ATA
Hot-swappable drive carrier
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Product Material
Plastic, aluminium
Power Source
Additional USB
Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7 Lion, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
2 years warranty
2.5"
Host Bus
SATA 3Gb/s, USB 2.0
Product Material
Plastic, aluminium
Supported Interface
SATA 3 Gb/s
Storage Controller
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Bays
1 x SATA 3Gb/s
1 x USB 2.0 - 4 pin mini-USB Type B , 1 storage - Serial ATA-300 - 7 pin Serial ATA
Compatible Bay
1 x external 3.5" x 1/3H
5.25" bay adaptor
1 x USB cable - external , 1 x Serial ATA cable
FCC, RoHS
Power Source
Additional USB
Accessories
StarTech.com 24" Serial ATA Cable
Quicklinx: 3ZLH | In Stock
£4.27
StarTech.com 18in SATA Serial ATA Cable
Quicklinx: 3ZLL | In Stock
£4.02
£3.81
£3.97
StarTech.com 36in SATA Serial ATA Cable
Quicklinx: 4KXJ | In Stock
£3.79
Scroll to top
