BT.com
Wishlist
StarTech.com 2x2 VGA Matrix Video Switch Splitter with Audio
StarTech.com 2x2 VGA Matrix Video...
£93.21
19 in stock
£93.21
Add to wishlist
Delivery
Standard 3-5 working days
The ST222MXA 2x2 VGA Matrix Switcher/Splitter allows you to share 2 distinct VGA inputs (as well as a corresponding audio source), between 2 independent displays or projectors.
Providing convenient push-button control, the VGA Matrix Switcher/Splitter allows each of the 2 input VGA signals and the corresponding audio, to be switched individually - meaning that you can have a different source showing on each display, or one source showing on both, offering maximum flexibility and control.
To ensure optimized VGA distribution and signal management over longer distance signal transmissions, the ST222MXA VGA Matrix Switch features a built-in signal booster that facilitates installation of displays at distances of up to 213-feet (65 meters) away from the source device, while maintaining flawless signal integrity.
StarTech.com 2x2 VGA Matrix Video Switch Splitter with Audio - video/audio switch - 2 ports
Video/audio switch - 2 ports
Subtype
VGA / audio
13 cm x 7.5 cm x 4.2 cm
450 g
1 year warranty
Bundled Services
1 year warranty
Enclosure Type
Desktop
Subtype
VGA / audio
Max Resolution
1920 x 1440 @ 85 Hz
Max Video Bandwidth
250 MHz
Status Indicators
Port status
2 x VGA input - HD-15 , 2 x VGA output - HD-15 , 2 x audio input - mini-jack , 2 x audio output - mini-jack
External power adapter
FCC, RoHS
13 cm
7.5 cm
4.2 cm
450 g
Limited warranty - 1 year
70 °C
0 - 95%
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
Accessories
£14.28
£6.90
£11.25
Scroll to top
