BT.com
Wishlist
StarTech.com 2U Vented Rack Mount Cantilever 2 Post Shelf - Mid/Center Mount - 150lbs / 68kg
StarTech.com 2U Vented Rack Mount...
£70.81
£70.81
Add to wishlist
Delivery
Standard Due date unavailable
Add a high capacity mid-mount vented shelf to almost any standard 2 post server rack. The CABSHF2POSTV 2U Heavy Duty Mid-Mount Vented Rack Mount Shelf for 2 Post Racks allows you to add a high capacity mid-mount fixed shelf to almost any standard 2 post server rack. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The included mounting brackets can be adjusted to accommodate different post depths, making this 2U shelf a universal solution for 2 post rack storage, while the vented design helps to improve airflow in the rack. Constructed using 1.6mm SPCC commercial grade cold-rolled steel, this durable 2 post rack shelf can hold up to 67kg (150lbs) of equipment - a perfect solution for storing non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
StarTech.com 2U Vented 2Post Rack Mount Cantilever Server Rack Cabinet Shelf - rack shelf - 2U
Rack shelf
Rack Size
19"
Height (Rack Units)
2U
Product Material
Cold-rolled steel
48.4 cm x 55.2 cm x 8.8 cm
4.1 kg
Adjustable depth, vented, cantilever
P/N: 2POSTRACK42, RK12OD
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
2U
48.4 cm
55.2 cm
8.8 cm
4.1 kg
Weight Limit
67.9 kg
Mounting Kit
Included
RoHS
Limited warranty - lifetime
Scroll to top
