BT.com
Wishlist
StarTech.com 2U Rack Mount Cantilever 2 Post Shelf - Mid/Center Server Rack- 150lbs / 68kg
StarTech.com 2U Rack Mount...
£68.88
6 in stock
£68.88
Add to wishlist
Delivery
Standard 3-5 working days
Add a high capacity mid-mount fixed shelf to almost any standard 2 post server rack. The CABSHF2POST 2U Heavy Duty Mid-Mount Rack Mount Shelf for 2 Post Racks allows you to add a high capacity mid-mount fixed shelf to almost any standard 2 post server rack.
The included mounting brackets can be adjusted to accommodate different post depths, making this 2U shelf a universal solution for 2 post rack storage. Constructed using 1.6mm SPCC commercial grade cold-rolled steel, this durable 2 post rack shelf can hold up to 67kg (150lbs) of equipment - a perfect solution for storing non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
StarTech.com 2U 2 Post Rack Mount Cantilever Server Rack Cabinet Shelf - rack shelf - 2U
Rack shelf
Rack Size
19"
Height (Rack Units)
2U
Product Material
Cold-rolled steel
48.4 cm x 55.2 cm x 8.8 cm
4.4 kg
Adjustable depth, cantilever
P/N: 2POSTRACK42, RK12OD
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
2U
48.4 cm
55.2 cm
8.8 cm
4.4 kg
Weight Limit
67.9 kg
Mounting Kit
Included
RoHS
Limited warranty - lifetime
Scroll to top
