BT.com
Wishlist
StarTech.com 2U Double-Sided Horizontal Cable Management Panel with Finger Duct & D-Ring Hooks
StarTech.com 2U Double-Sided...
£46.95
£46.95
Add to wishlist
Delivery
Standard Due date unavailable
Organize horizontal cabling in your server rack, with a combination Finger Duct / D-Ring Hook panel. The CMPNL2U 2U Horizontal Cable Management Panel mounts to a standard 19" 2 or 4-post server rack to help you organize horizontal cabling, using the combination of a finger duct and D-Ring Hooks.
Constructed of high-quality steel, the cable organizer is designed as a double-sided solution offering cable management on both the front and back of the panel. The front is equipped with 4 horizontal D-Ring hooks, while the back has 2 additional hooks as well as a cable duct with a series of fingers that help you route your cables where you need them, and reduce cable strain in the process..
As an added benefit, the panel also promotes proper airflow through the rack by closing off open spaces between equipment. For easy installation, this horizontal cable organizer comes complete with 2 sets of rack screws (10/32 and 12/24).
StarTech.com 2U Finger Duct & D-Ring Hook Horizontal Cable Management Panel - rack cable management panel - 2U
Rack cable management panel
Package Content
8 nuts, 4 x screw (10-32), 4 x screw (12-24), 24 cable clamps
Height (Rack Units)
2U
Product Material
Steel
48.2 cm x 10.22 cm x 8.81 cm
1.4 kg
2 years warranty
P/N: 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1219SIDEM, RK1219WALLOH, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK960CP, RKQMCAB12, RKWOODCAB12
Product Material
Steel
Package Content
Height (Rack Units)
2U
48.2 cm
10.22 cm
8.81 cm
1.4 kg
RoHS
P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1219SIDEM, RK1219WALLOH, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK960CP, RKQMCAB12, RKWOODCAB12
Scroll to top
