BT.com
Wishlist
StarTech.com 2U Double-Sided Horizontal / Vertical Cable Management Panel with Finger Duct
StarTech.com 2U Double-Sided...
£48.90
6 in stock
£48.90
Add to wishlist
Delivery
Standard 3-5 working days
Organize horizontal and vertical cabling in your server rack, with a combination Finger Duct / D-Ring Hook panel. The CMPNL2UC 2U Cable Management Panel mounts to a standard 19" 2 or 4-post rack to help you organize both horizontal and vertical cabling, using the combination of a finger duct and D-Ring hooks.
Constructed of high-quality steel, the cable organizer is designed as a double-sided solution offering cable management on both the front and back of the panel. The front is equipped with 4 vertical and 4 horizontal D-Ring hooks, while the back has 2 additional hooks as well as a cable duct with a series of fingers that help you route your cables where you need them, and reduce cable strain in the process.
As an added benefit, the panel also promotes proper airflow through the rack by closing off open spaces between equipment. For easy installation, this horizontal cable organizer comes complete with 2 sets of rack screws (10/32 and 12/24).
Note: The hooks on this cable management system extend past 19 inches. As a result certain racks with close spaced or inset rack mount holes may not be compatible with this product.
StarTech.com 2U Finger Duct & D-Ring Hook Cable Management Panel - rack cable management panel - 2U
Rack cable management panel
Package Content
8 nuts, 4 x screw (10-32), 4 x screw (12-24), 24 cable clamps
Height (Rack Units)
2U
Product Material
Steel
51.6 cm x 10.22 cm x 8.81 cm
1.5 kg
2 years warranty
P/N: 4POSTRACK12U, 4POSTRACK25U
Product Material
Steel
Package Content
Height (Rack Units)
2U
51.6 cm
10.22 cm
8.81 cm
1.5 kg
RoHS
Scroll to top
