BT.com
Wishlist
StarTech.com 2m (6 ft) Long Right Angle Apple 30-pin Dock Connector to USB Cable - Stepped Connector
StarTech.com 2m (6 ft) Long Right...
£15.68
2 in stock
£15.68
Add to wishlist
Delivery
Standard 3-5 working days
Charge or Sync your iPhone, iPod, or iPad over longer distances, keeping the cable out of the way. The USB2ADC2MR USB cable for iPhone, iPod and iPad (2m) features a right-angled Apple (30-pin) Dock Connector which positions the cable in such a way that it allows you to easily access your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
The longer USB to iPhone cable design offers 2-meters in cable length to overcome distance restrictions while still providing full charging power.
Plus, the USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
As an alternative, StarTech.com also offers a 2m Left Angle Apple 30-pin Dock Connector to USB Cable (USB2ADC2ML), which provides the same convenience as this right-angled cable, but allows you to connect to your iPhone, iPod or iPad from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 2m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 2m Right Angle Apple 30-pin Dock to USB Cable iPhone iPod iPad - charging / data cable - 2 m
Cable
Charging / data cable
Shielded
American Wire Gauge (AWG)
24
Length
2 m
Connector
USB - male
Connector (Second End)
Apple Dock - male
Angled connector
Apple iPad (3rd generation); iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Cable Type
Charging / data cable - angled connector
Shielded
24
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Nickel
White
Connector
4 pin USB Type A - male
Apple Dock connector - male
RoHS, MFI
Limited warranty - lifetime
Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPhone 3G, 3GS, 4, 4S , Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini , Apple iPod nano (1G, 2G, 3G, 4G, 5G, 6G) , Apple iPod touch (1G, 2G, 3G, 4G)
Accessories
£8.04
Scroll to top
