BT.com
Wishlist
StarTech.com 25 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Delivery
Standard Due date unavailable
This 25ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 25 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 7.6 m
VGA cable
Triple shielded twisted pair coaxial
Cable Features
Moulded , nickel plated connectors, ferrite bead
Length
7.6 m
Connectors
1 x 15 pin HD D-Sub (HD-15) - male
Connectors (Other Side)
P/N: ST122LEU, RACKCONV1901, VGA2TV2WAY2, USBVGADOCK2, USBVGADOCKGB, USBVGADOCK, ST122LE, VS815RVGAGB, VS415RVGAGB, ST128LGB, ST124LGB, ST122LGB, VS415RVGA, VGAHD2HDMIGB, ST128L, ST124L, ST122L, VGAHD2HDMI, VID2VGATVGB, VGA2TV2WAYGB, VGA2DVIIGB, VGA2DVII, VGA2TV2WAY, VID2VGATV, ST222MX, SV421DD
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Cable Features
Length
7.6 m
Colour Category
Connectors
StarTech.com 2 Port DVI PS/2 KVM Switch, 2 Port Matrix High Resolution VGA Video Splitter, 2 Port VGA Dual Monitor KVM Switch with PS/2, 2 Port VGA Video Splitter - 250 MHz, 2 Way High Resolution HDTV VGA Video Converter with Scaler, 2 Way VGA HDTV Video Converter with Scaler, 4 Port High Resolution VGA Video Switch with Remote, 4 Port VGA Dual Monitor KVM Switch with PS/2, 4 Port VGA Video Splitter - 250 MHz, 4-in-1 USB VGA Adapter and Docking Station, 8 Port VGA Video Selector Switch, Component / Composite / S-Video to VGA / HDTV Scaler / Converter, Composite and S-Video to VGA Video Converter, VGA to DVI-I Video Converter with Scaler, VGA to HDMI Video Converter with Audio , StarTech.com VGA Video Splitter / Distribution Amplifier 8 Port - 250 MHz
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good quality with hd tv
Reviewed by Anonymous on 29/12/2008
Bought this cable a few weeks ago to connect my desktop computer to my 32 inch high definition television across the room. As soon as i took it out of the packet i knew it was good quality as the wiring is extra thick to help stop interference. Connected it up and the picture quality was amazing! I would say its a better picture quality than the standard vga cable that came with my pc monitor but it could be down to the tv. All in all ive had no problems with it at all and am considering buying another one for my girlfriends tv. Also at this price its cheaper than the 4.6 metre cable with the extra 3 metres! Well worth buying.
5* Good quality over a long distance!
Reviewed by Matt on 14/02/2007
You need a high quality cable if you plan to extend a video display cable over a long period. This cable is long and extends to my LCD and it gives a very good quality picture, 7.6m away!
Scroll to top
