BT.com
Wishlist
StarTech.com 24in SATA to Left Angle SATA Serial ATA Cable
Delivery
Standard Due date unavailable
Make a left-angled connection to your SATA drive, for installation in tight spaces. The SATA24LA1 Left Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a left-angled SATA receptacle, providing a simple 24-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The left-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers a 24in Right Angle SATA cable (SATA24RA1), which provides the same simple installation as this left angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
StarTech.com 24in SATA to Left Angle SATA Serial ATA Cable - SATA cable - 61 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Shielded
Left-angled connector
Length
61 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 25SATSAS35
Storage Cable Type
SATA cable
Interface Speed
Shielded
Shielding Material
Length
61 cm
Red
Connector
RoHS
P/N: 25SATSAS35
Scroll to top
