BT.com
Wishlist
StarTech.com 24in Right Angle SATA Cable
Delivery
Standard Due date unavailable
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATARA24 Right Angle (90-degree) SATA cable (24in) enables you to plug in your SATA hard drive in hard to reach areas or tight spaces, using right-angled SATA connectors to reduce the amount of space required at the connection point and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com Right Angle SATA Cable - SATA cable - 61 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Cable Features
Right angle connector
Length
61 cm
Connectors
1 x 7 pin Serial ATA - receptacle
Connectors (Other Side)
Red
P/N: PEXSATA24E, PCISATA4R1
Storage Cable Type
SATA cable
Interface Speed
Cable Features
Length
61 cm
Red
Colour Category
Red
Connectors
StarTech.com 2 Port eSATA + 4 Port SATA PCI Express x4 SATA Controller Adapter Card, 4 Port PCI SATA RAID Controller Adapter Card
Scroll to top
