BT.com
Wishlist
StarTech.com 2 Way High Resolution HDTV VGA Video Converter with Scaler
Delivery
Standard Due date unavailable
Convert and scale PC to HDTV or HDTV to PC resolutions. The VGA2TV2WAY2 two way (bi-directional) VGA to component (HDTV) or component (HDTV) to VGA video converter/scaler combines the features of a format converter and a video scaler, providing a cost-effective way to display and adjust VGA (PC) or component YPbPr (HDTV) feeds to fit the requirements of your display.
Designed to provide simplicity and convenience, the VGA HDTV video converter/scaler automatically detects the source input resolution, allowing you to select the output resolution and refresh rate you require through an easy to use On-Screen Display (OSD) menu. The built-in scaling functionality allows you to alter the output signal to a resolution that is compatible with your destination display or projector.
The VGA2TV2WAY2 is a replacement to the VGA2TV2WAY and offers increased compatibility with newer displays, VGA bypass port, and a more advanced OSD menu.
StarTech.com 2 Way High Resolution HDTV VGA Video Converter with Scaler video converter - black
Video converter
Video Input
VGA
2 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x component video output - RCA x 3 (with adapter) , 1 x component video input - RCA x 3 (with adapter) , 1 x VGA input - 15 pin HD D-Sub (HD-15)
10.2 cm x 15.7 cm x 2.5 cm
Enclosure Colour
2 years warranty
Video converter
2 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x component video output - RCA x 3 (with adapter) - male , 1 x component video input - RCA x 3 (with adapter) - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - female
Video Output
Supported Display Graphics
VGA (640x480), XGA (1024x768), SVGA (800x600), SXGA (1280x1024), UXGA (1600x1200), 1920x1200, 1280x800, 1680x1050
Analogue Video Format
NTSC, PAL
1 x VGA / component video adapter - 91.44 cm , 1 x VGA cable - 1.22 m
FCC, RoHS
10.2 cm
15.7 cm
2.5 cm
332 g
Enclosure Colour
Accessories
£6.97
£10.27
Scroll to top
