BT.com
Wishlist
StarTech.com 2 Port VGA Video Splitter - 250 MHz
Sorry but this product has been discontinued.
View used stock
Delivery
Standard 3-5 working days
The ST122LGB 2 port VGA video splitter allows a single VGA source to display VGA video onto two monitors simultaneously. Perfect for classrooms, tradeshows, or in-store displays where high quality video on several monitors is needed. The simple plug and play operation makes setup quick and easy so you can be up and running in minutes.
The ST122LGB supports displays with up to 250 MHz of bandwidth, providing brilliant resolutions up to 1920x1440. A built-in booster circuit lets you situate your displays up to 210 ft away from your source.
StarTech.com 2 Port VGA Video Splitter - 250 MHz - video splitter - 2 ports - desktop
Video splitter - 2 ports
Enclosure Type
Desktop
Subtype
VGA
Ports
2 x VGA
13.1 cm x 6.5 cm x 2.6 cm
220 g
United Kingdom
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
VGA
Ports
2 x VGA
Max Resolution
1920 x 1440
Max Video Bandwidth
250 MHz
2 x VGA output - HD-15 , 1 x VGA input - HD-15
External power adapter
FCC
United Kingdom
13.1 cm
6.5 cm
2.6 cm
220 g
Accessories
£6.90
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Cables required
Reviewed by Mr Helpful on 27/01/2009
Please note, this product requires the following cables:
PC to switchbox - MALE to FEMALE VGA cable
switchbox to device (TFT, Projector, etc) - MALE to MALE VGA cable.
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: 4H1F 036283
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£9.99
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
