BT.com
Wishlist
StarTech.com 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac
StarTech.com 2 Port USB Keyboard...
£30.31
6 in stock
£30.31
Add to wishlist
Delivery
Standard 3-5 working days
Control and transfer files between two Windows and/or Mac systems using a single keyboard and mouse. The SVKMS2 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac enables you to control two computer systems using a single keyboard and mouse set, and offers the ability to transfer files between the connected Windows and/or Mac systems.
Offering automated installation (no additional software or drivers required), this compact KM switch cable connects your Windows and/or Mac systems using a standard USB 2.0 port to make switching between systems as simple as moving the mouse over to your second display, or using hot-keys.
This simple 2 port USB KM switch also provides the added benefit of clipboard sharing so you can copy and paste text from one system to another, or drag and drop files for effortless transfers and data management.
StarTech.com 2 Port USB KM Switch Cable w/ File Transfer for PC and Mac - keyboard/mouse switch - 2 ports
Keyboard/mouse switch - 2 ports - USB
Subtype
USB
18.5 cm x 1.8 m x 11.5 cm
42 g
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.6 - 10.8, Windows 10 (32/64 bits)
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
USB
Keyboard / Mouse Interface
USB
2 x USB - Type A , 1 x keyboard (USB) - Type A
WHQL, FCC, RoHS
18.5 cm
1.8 m
11.5 cm
42 g
50 °C
0 - 85% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
55 °C
Accessories
£10.72
Scroll to top
