BT.com
Wishlist
StarTech.com 2-Port USB Fax Modem - 56K
Delivery
Standard Due date unavailable
Add two RJ-11 ports to your computer through USB, for dial-up Internet and fax communication. This USB to 2-port 56k modem lets you add two RJ-11 jacks to your computer that you can use for dial-up Internet access and external fax modem support.
It's almost impossible to find a modern computer with a dial-up modem, even though modems are still commonly needed for fax communication and rural Internet connections at both the home and the office.
This two-port modem gives you the freedom to upgrade your existing computer or server and still be able to send or receive fax communications and connect to the Internet using the same device.
This hardware controller-based modem saves system resources and minimizes load on your computer's CPU, using on-chip processing to deliver dial-up access without taxing your computer performance.
Plus, with support for transfer rates up to 56 Kbps (data) and 14.4 Kbps (fax), and compatibility with the latest transmission standards (V.92, V.90, etc.), this versatile USB modem can be used as a backup Internet connection, or in rural areas where broadband connections are not available. The modem also supports both Windows and Mac OS platforms, providing the compatibility needed for true convenience.
To ensure portability the USB modem features a compact, lightweight design and is powered through the USB host connection. This portable design makes this modem the perfect accessory to carry with your laptop computer, fitting easily into your laptop bag or carrying case.
StarTech.com 2-Port External USB Modem - 56K Hardware Based Fax Modem - fax / modem
Fax / modem - USB
External
Max Transfer Rate
56 Kbps
Protocols & Specifications
Bell 103, ITU V.21, Bell 212A, ITU V.22, ITU V.29, ITU V.32, ITU V.32bis, ITU V.34, ITU V.90, ITU V.17, ITU V.23, ITU V.27ter, ITU V.92
Max Fax Transfer Rate
14.4 Kbps
Error Correction Protocol
ITU V.42
Data Compression Protocol
MNP-5, ITU V.42bis, ITU V.44
Microsoft Windows 2000, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
3.5 cm x 8 cm x 2 cm
85 g
2 years warranty
Fax / modem
External
Modem
Bus
USB
Wired
Conexant Systems CX93010
Max Transfer Rate
56 Kbps
56K Technology
V.90, V.92
ITU V.42
14.4 Kbps
USB powered
1 x phone line - RJ-11 x 2 , 1 x USB - Type A
1 x phone cable
FCC, RoHS
Software Included
Drivers & Utilities
3.5 cm
8 cm
2 cm
85 g
10 - 90% (non-condensing)
Accessories
£5.25
£3.68
£4.53
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* It works but
Reviewed by Mark on 23/04/2016
You had better buy a connector. I had tried a filter from sky but when I tried to send a fax the broadband cut off. I am now removing the broadband first and then plugging the RJ11 plug in, I honestly wish that this had come complete with an adapter or even brought into the modern age and had used a better connector. I sent two faxes hoping to get a reply to confirm that it worked, and thankfully I got one reply back. Delivery was quick however picking and packing was slower than Dabs. However it was still cheaper than other places that I looked at.
Scroll to top
