BT.com
Wishlist
StarTech.com 2 Port USB DVI KVM Switch with Audio and Cables
StarTech.com 2 Port USB DVI KVM...
£108.72
13 in stock
£108.72
Add to wishlist
Delivery
Standard 1-3 working days
This USB DVI KVM Switch provides access and control of two DVI enabled, USB controlled computers, as well as independent audio/microphone switching that allows an uninterrupted audio experience, even when switching back and forth between computers.
The perfect KVM switch for multimedia applications, SV211KDVIGB supports both digital and analog video signal transmissions for display resolutions of up to 1900x1200 (digital) and 2048x1536 (analog). The switch also features an integrated USB 2.0 hub that allows you to share two high-speed USB devices between computers.
Compatible with Mac, Linux or PC Based computers, the DVI KVM switch (SV211KDVIGB) is a great addition for a broad range of environments including SOHO (Small or Home Offices), gaming, multimedia production workstations and more, and features a compact form factor design that helps preserve valuable deskspace.
A complete, out-of-the-box solution, this DVI KVM Switch (SV211KDVIGB) includes two 4 ft. DVI/Audio & Mic combo cables that simplify computer connection to the switch and help to eliminate the cable clutter that could result from using multiple cables.
StarTech.com 2 Port USB DVI KVM Switch with Audio and Cables - KVM / audio / USB switch - 2 ports - desktop
KVM / audio / USB switch - 2 ports - USB
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
USB 1.1, USB 2.0
15.4 cm x 6.6 cm x 2.7 cm
White
United Kingdom
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
USB 1.1, USB 2.0
2 x DVI-I , 2 x USB 2.0 - Type B , 1 x DVI-I , 2 x USB 2.0 - Type A , 1 x microphone - mini-jack , 1 x speakers - mini-jack
External power adapter
White
2 x USB cable - 1.2 m , 2 x keyboard / mouse / video / audio cable - 1.2 m
FCC, RoHS
United Kingdom
Software Included
Drivers & Utilities
15.4 cm
6.6 cm
2.7 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Wonderful Device - Rubbish Power adapter
Reviewed by Bonzo Doggy on 01/03/2010
This is a lovely KVM switch spoilt by a cheap power adapter. I have now had two of these devices and, while they worked, they were great. However, in both cases the power adapter failed within a short time of installation. BT returns service has been great, but having the I/O devices go down in the middle of a session is quite distressing - even shutting down the computer is a problem. Yes, I know you can press the power switch but it's not recommended.
Scroll to top
