BT.com
Wishlist
StarTech.com 2 Port USB 3.0 Hub - SuperSpeed Compact Black
Delivery
Standard Due date unavailable
Add 2 external USB 3.0 ports from a single USB connection. The ST2300CUSB3 2-Port SuperSpeed USB 3.0 Hub is a compact solution for expanding the USB capability of your computer, by turning a single USB 3.0 port into 2 USB 3.0 ports - the perfect companion for laptops/netbooks that only offer a limited number of USB ports. The USB hub supports USB 3.0 data bandwidth (5 Gbps - up to 10x more than USB 2.0) and is backward compatible with USB 2.0 and 1.1/1.0 devices, ensuring flawless performance from all of your USB peripherals/devices, regardless of their age. Ideal for travelers who require portability, the USB 3.0 hub features a compact design with a built-in cable, making it easy to carry, with no additional cables or accessories needed for setup.
StarTech.com 2 Port USB 3.0 Hub - SuperSpeed Compact - hub - 2 ports
Hub - 2 ports
Subtype
USB
Ports
2 x SuperSpeed USB 3.0
USB 1.1, USB 2.0, USB 3.0
4.9 cm x 5.9 cm x 1.3 cm
39 g
2 years warranty
Hub - 2 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Status Indicators
Power, link/activity
2 x USB 3.0 Type A , 1 x USB 3.0 Type A
FCC, RoHS
4.9 cm
5.9 cm
1.3 cm
39 g
50 °C
20 - 93%
Min Storage Temperature
-40 °C
Max Storage Temperature
55 °C
Accessories
£7.35
£10.71
Scroll to top
