BT.com
Wishlist
StarTech.com 2 Port USB 3.0 Dual System Swap Cable KVM Switch with File Transfer
StarTech.com 2 Port USB 3.0 Dual...
£64.86
1 in stock
£64.86
Add to wishlist
Delivery
Standard 3-5 working days
Share video, keyboard/mouse input and transfer files between 2 systems through USB. The SVUSB3DSA 2-Port USB 3.0 Dual System Swap KVM Switch lets you share video, keyboard/mouse input and transfer files between two Windows systems, all through a standard USB 3.0 connection to each. Once connected, you can move your mouse cursor naturally between systems for seamless KVM control.
This USB KVM switch features display sharing (extended or mirrored mode) from either computer, turning your second laptop, tablet or desktop into a shared display. Integrated touchscreen support means that if one or both of your connected systems has a touchscreen, you can use touch to control the computer being mirrored or extended.
Integrated support for file transfers makes it easy to share files through the USB 3.0 KVM connection. With the click of a button, a file transfer window opens that allows you to either drag-and-drop or copy / paste files to any directory on the opposite computer. The device also supports clipboard sharing, so you can copy and paste text from one system to another.
The USB 3.0 interface provides a 5 Gbps data channel to ensure fast file transfers and smooth video streaming / sharing operations, while offering backward compatibility with USB 2.0.
StarTech.com 2 Port USB 3.0 Dual System Swap KVM Switch w/ File Transfer - direct connect adapter
Direct connect adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
USB 3.0
1.9 cm x 4.9 cm x 0.9 cm
36 g
USB 2.0, USB 3.0
USB 2.0, USB 3.0
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
2 years warranty
External
SuperSpeed USB 3.0
Ports
USB 3.0
Wired
USB 2.0, USB 3.0
USB 2.0, USB 3.0
1 x USB 3.0 - 9 pin USB Type A
1 x USB cable - 1.5 m
FCC, RoHS
Software Included
Drivers & Utilities
System Requirements Details
Core i3 - 2.8 GHz - RAM 2 GB
1.9 cm
4.9 cm
0.9 cm
36 g
50 °C
0 - 85% (non-condensing)
Scroll to top
