BT.com
Wishlist
StarTech.com 2 Port SuperSpeed USB 3.0 VGA KVM Switch with Audio and Cables
StarTech.com 2 Port SuperSpeed USB...
£144.78
£144.78
Add to wishlist
Delivery
Standard Due date unavailable
Control 2 VGA, USB 3.0 equipped PCs with a single monitor, keyboard, mouse and audio peripheral set. The SV231U3A 2 Port SuperSpeed USB 3.0 VGA KVM Switch with Audio and Cables lets you control 2 VGA, USB 3.0 equipped PCs with a single monitor, keyboard, mouse and audio peripheral set.
This USB 3.0 KVM Switch offers an integrated 2 port hub that supports USB 3.0 data rates of up to 5 Gbps, and is backward compatible with USB 2.0 and 1.1/1.0 devices, ensuring flawless performance for your USB peripherals.
Offering support for high resolutions (up to 2048x1536), this 2 port VGA KVM switch has the ability to drive large VGA displays with ease, ideal for graphical applications that require high-res video output.
StarTech.com 2 Port SuperSpeed USB 3.0 VGA KVM Switch with Audio and Cables - KVM switch - 2 ports
KVM switch - 2 ports - USB
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
AC 120/230 V
16.5 cm x 8.9 cm x 4.6 cm
0.94 kg
North America, United Kingdom, Europe
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
Built-in Devices
USB 3.0 hub
Status Indicators
Port status
2 x USB 3.0 - Type B , 2 x VGA - HD-15 , 2 x audio / headphones - mini-jack , 2 x microphone input - mini-jack , 2 x USB 3.0 - Type A , 1 x VGA - HD-15 , 1 x audio / headphones - mini-jack , 1 x microphone input - mini-jack , 2 x keyboard (USB) / mouse (USB) - Type A
External power adapter
AC 120/230 V
2 x VGA cable , 2 x USB cable , 2 x audio cable
FCC, RoHS
16.5 cm
8.9 cm
4.6 cm
0.94 kg
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
Accessories
£9.07
£4.23
Scroll to top
