Click to visit BT.com
BT.com
Wishlist
StarTech.com 2 Port Serial ATA & 1 Port ATA IDE PCI Card
3.0*
Quicklinx: 4YLMWS00
Mfr#: PCISAT2IDE1
StarTech.com's 2S1I PCI SATA IDE Combo Controller Adapter Card adds two Serial ATA ports and one Ultra ATA133 channel (supports 2 IDE drives) through simple installation in a single PCI slot. The SATA/IDE controller adapter card also includes a low profile bracket for adapting to slimline or small form factor system applications. This high quality adapter card is the perfect upgrade for power-users.
StarTech.com 2S1I PCI SATA IDE Combo Controller Adapter Card - storage controller (RAID) - ATA-133 / SATA 1.5Gb/s - PCI/66 MHz
Storage controller (RAID) - plug-in card
Bus Type
PCI/66 MHz
Data Transfer Rate
150 MBps
Supported Devices
Disk array (RAID)
Channel Qty
3
Max Storage Devices Qty
4
RAID Level
RAID 0, RAID 1, JBOD
Microsoft Windows NT 4.0, Microsoft Windows 98/ME/2000/XP, Microsoft Windows Vista
Host Bus
PCI/66 MHz
Storage Controller
Data Transfer Rate
150 MBps
Supported Devices
Disk array (RAID)
Channel Qty
3
4
RAID Level
1 x ATA-133 - 40 PIN IDC ( internal ) , 2 x SATA 1.5Gb/s - 7 pin Serial ATA ( internal )
Compatible Slots
1 x PCI / 66 MHz
FCC, RoHS
Software Included
Drivers & Utilities
Service & Support Details
Limited warranty - lifetime
4YLM StarTech.com 24" Serial ATA Cable In Stock £4.10
4YLM StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £5.42
4YLM StarTech.com 18in SATA Serial ATA Cable In Stock £3.87
4YLM StarTech.com 36in Dual Drive Ultra ATA IDE Cable In Stock £4.17
4YLM StarTech.com 18in Dual Drive Ultra ATA IDE Hard Drive Cable In Stock £4.12
4YLM StarTech.com 18in Round Dual Drive Ultra ATA IDE Hard Drive Cable In Stock £3.66
4YLM StarTech.com 24in Dual Drive Ultra ATA IDE Hard Drive Cable In Stock £1.44
4YLM StarTech.com 36in SATA Serial ATA Cable In Stock £3.66
Customer reviews
Write a review for the StarTech.com 2 Port Serial ATA & 1 Port ATA IDE PCI Card here!
Warning
Reviewed by Tony Brook. Review Posted 30/09/2008
This product does what it says "on the tin"; however, it is less than perfectly clear that it only supports SATA I drives, whereas virtually all new drives require SATA II support. I would recommend the slightly more expensive four SATA II port PCISATA4R1 model.
  • Overall 3*
  • Ease of use 5*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
