BT.com
Wishlist
StarTech.com 2 Port Serial ATA & 1 Port ATA IDE PCI Card
Delivery
Standard Due date unavailable
StarTech.com's 2S1I PCI SATA IDE Combo Controller Adapter Card adds two Serial ATA ports and one Ultra ATA133 channel (supports 2 IDE drives) through simple installation in a single PCI slot. The SATA/IDE controller adapter card also includes a low profile bracket for adapting to slimline or small form factor system applications. This high quality adapter card is the perfect upgrade for power-users.
StarTech.com 2S1I PCI SATA IDE Combo Controller Adapter Card - storage controller (RAID) - ATA-133 / SATA 1.5Gb/s - PCI/66 MHz
Storage controller (RAID) - plug-in card
Bus Type
PCI/66 MHz
Data Transfer Rate
150 MBps
Supported Devices
Disk array (RAID)
Channel Qty
3
Max Storage Devices Qty
4
RAID Level
RAID 0, RAID 1, JBOD
Microsoft Windows NT 4.0, Microsoft Windows 98/ME/2000/XP, Microsoft Windows Vista
Host Bus
PCI/66 MHz
Storage Controller
Data Transfer Rate
150 MBps
Supported Devices
Disk array (RAID)
Channel Qty
3
4
RAID Level
1 x ATA-133 - 40 PIN IDC ( internal ) , 2 x SATA 1.5Gb/s - 7 pin Serial ATA ( internal )
Compatible Slots
1 x PCI / 66 MHz
FCC, RoHS
Software Included
Drivers & Utilities
Service & Support Details
Limited warranty - lifetime
Accessories
StarTech.com 24" Serial ATA Cable
Quicklinx: 3ZLH | In Stock
£4.27
£5.97
StarTech.com 18in SATA Serial ATA Cable
Quicklinx: 3ZLL | In Stock
£4.02
£4.35
£4.29
StarTech.com 36in SATA Serial ATA Cable
Quicklinx: 4KXJ | In Stock
£3.79
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Warning
Reviewed by Tony Brook on 30/09/2008
This product does what it says "on the tin"; however, it is less than perfectly clear that it only supports SATA I drives, whereas virtually all new drives require SATA II support. I would recommend the slightly more expensive four SATA II port PCISATA4R1 model.
Scroll to top
